problem whit missfires ??? - FirebirdV6.com/CamaroV6.com Message Board
  • problem whit missfires ???
    ok i replace wires and spark plugs
    if i hit 90mph at 4th gear no missfire
    but if i step on the gas and i hit the same 90mph
    now at 3rd gear the car trows me a ses light
    (multiple random missfire)
    does anyone has have the same problem??
    im thinking maybe the coils ar bad ???
    what should i do ??? [img]graemlins/stickpoke.gif[/img]
    headers, high flow cat, slp loudmouth
    powerdyne supercharger 6psi
    GT2 cam. all done by myself :banana:
    Hell yea
    At what RPM do you misfire and does it happen in any other gear at different speeds?
    Are you sure its not just the rev limiter kicking in?
      it happens only at full trotle on 3rd gear at 90mph the rpm is like 4000
      if i hit 90mph on 4rd gear i dont get SES light
      it is very weird
      i took it to the dealler ship ad they said it was the plugs and wires. so i replace both
      [ September 14, 2004, 12:44 AM: Message edited by: BAD BIRD ]
      Hell yea
        im going to replace the coils
        is there a place on the net where i can get theme????
        Hell yea
          just about any parts store will have coil packs for this car in stock-- why bother ordering from the net unless you're getting something really esoteric?
          \'00 f-bird 3.8 M5 coupe, pewter metallic<br />Torsen LSD, Pro 5.0 shifter, Spec stage 1 clutch, Y87 muffler, aftermarket stereo<br />-more fun than the Oldsmobile it replaced...
            thanks
            terminaldegree
            Hell yea
              ok i dont know what to do next i just nstall the new coil packs an i still having the same problem
              do you guys have any ideas
              Hell yea
                Could be the speed limiter. Should kick in at 97 mph if it's not tuned (assuming you had 3.08s before).
                Matt
                1998 Mystic Teal Camaro M5
                  but will that cause the SES light code multiple random missfire
                  Hell yea
                    The same thing happens to me if I don't use 92/93 octane. Don't know why.
                    94 Firebird 3.4 - RIP<br />97 Firebird 3.8 - In the works
                      whe are on a ****ing dilema
                      Hell yea
                        Wait, do you have 3.73s installed or not??
                        http://www.camarov6.com/ubb/ultimate...;f=23;t=003803
                        Matt
                          Is it just 3rd at high rpms or every gear? Injectors or coils if not the limiter?
                          2001 V6 Camaro - VTEC Badged, Abbott Racing Heads Sticker, and Loud A$$ Exhaust<br /><br /><b>BUILT NOT BOUGHT</b><br /><br />14.0 @ 96.44 MPH (Street Tires, Before Tranny)<br /><br /> <a href=\"http://members.cardomain.com/6pakcamaro54\" target=\"_blank\">http://members.cardomain.com/6pakcamaro54</a>
                            is only 3rd at high rpms
                            allready put brand new coils
                            Hell yea
