Alright I have a 98 and the angled throtle body is getting on my nerves. Is there any way that i can straighten it, or do I need to suck it up and buy a new intake manifold(ex: from a 99 or newer) to correct the angle?
Throtle body
Not worth it. I would almost say it can't be done, but with enough work it probably could. You'd have to get a 99+ intake manifold and throttle body, which is drive-by-wire. So then you'd have to convert the car to drive-by-wire, which would require a new PCM, servo, pedal setup, etc.Matt
1998 Mystic Teal Camaro M5
Originally posted by pgriffith:
You might be able to make the 98 TB fit on the 99 manifold and it would be streight. But why?Matt
