Gapping plugs / MSD DIS-4 - FirebirdV6.com/CamaroV6.com Message Board
  • Gapping plugs / MSD DIS-4
    I just installed my msd dis -4 box yesterday.
    WOULD I BENEFIT FROM GAPPING MY PLUGS WIDER THAN STOCK (.035), TO GET A HOTTER MORE POWERFUL SPARK. SECOND WILL THE NEW IGNITION BE ABLE TO HANDLE IT. ANY OTHER TUNING TIPS FOR THE 3.4 WOULD BE APPRECIATED! THANKS
    I have a 3.4 camaro, freshly rebuild with the following:
    -LT1 TB and custom intake & ported lower intake
    -10.7 compression (.030 over)
    -fully ported & polished heads
    -headers, full exhaust
    -msd blaster coils and dis -4
    rais the gap slowy i have see the MSD arch .10 before lol....
    try .045
    www.turbov6camaro.com
    1997 3800 Series II Camaro
      what kind of cam do you have in your 3.4? when i put a 206/212 in mine, it made it run rich, i failed my emissions and had to get a waiver, but the msd dis 4 has helped lean it out. sounds like you have a strong 3.4.
      95 3.4 m5- comp 206/212, 1.6 roller rockers, pacesetter headers, magnaflow cat, dynomax 18\" bullet muffler, ss muffler and tips, msd 8.5 wires, 32mm sway, umi sfc,
        i have a COMP custtom grind 224 224 with a 4 degree advance, and 112 lsa, i love it, and so does the car! yeah, i run rich at idle, and i run bosch design 2 19lb ford fuel injecters. i haven't run the car with the msd yet, but it started a lot easier. so the advice is to try gapping them a little at a time, .045. thanks
          the stock gap for our cars is .045 so maybe try gapping them more like .050.
