My car tends to have a misfire happened in the first cylinder once the car hits about 100 MPH or if i really get on in such as pedal to the floor. Changed spark plugs, wires, and the and first cylinder ignition coil. What else is left? I was thinking that maybe i had low compression in that cylinder but not burning an ounce of oil so i really dont know.I really need some suggestion to what may be wrong. Perhaps someone else has had this problem?
Misfire Question
does your car shake a little bit? Could be a fuel injector~The Guru\'s Guru~<br />1999 Camaro,K&N,!MAF<br />!airsilencer,3.08s,<br />NGK-TR6\'s,Taylor Blue 8mm wires,FRAM,A4,Catco Cat, Magnaflow 3 inch catback,transgo shift kit<br />Waiting: RK sport headers, custom y pipe electric cutout<br /><a href=\"http://www.cardomain.com/id/divinejc\" target=\"_blank\">www.cardomain.com/id/divinejc</a>
