Grounding kit - FirebirdV6.com/CamaroV6.com Message Board
Grounding kit
This topic is closed.
  • Grounding kit
    I think i have allready asked this, but no one makes a grounding kit for our cars right? Can someone tell me how to make a home made on, i know the gains are small but i have some extra time, and extra monster cable sitting around my house, and i want to put them both to good work.
    2002 M5 camaro- VTR CAI, custom cat-back exhaust, battery compacitor, pullie, lowering springs, 32mm sway bar, cross-drilled slotted rotars. 1-10\" L7 in cubby.
    Upgrading the "big 3" wires would be a good start, then maybe another from the block to chassis....I saw a diagram for one of these but that's about all I can remember....sorry.
    2000 3.8L Firebird, Silver Metallic<br /><br />\"Yes, London. You know, fish, chips, cup o\' tea, bad food, worse weather, Mary f***in\' Poppins, London!!\"
      Don't know and don't care if any one makes them for our cars.
      One thing I all ways tell people is that all most any kind of "kit" is a waste of money, and that a lot of them are put together with off the shelf stuff that you could get for way cheaper.
      You could make one so easy and so cheap it isn't funny.
      If you have wire laying around get some solderless connecters that will fit them for a few $. Then all you have to do is cut, crimp and install.
      Wire brush the aera where you are going to install them.
      Make sure you hook the alt. to the block and the block to the battery and then go from there.
      For me I am going to get rid of the grounds for the engine sencors, controals and ECU all together. I'll wire them so every thing is isolated from the frame and wired to one shunt at the batt.
        IMHO its wasted time and weight.
          just a plain waste. It's something a ricer would buy and use for an excuse when he lost "my grounding kit must have been loose making my Vtec not kick in"
          your car is well grounded as it is.
            Not if you have a big aftermarket sound system.
            \"Well, we don\'t care how bad-*** some dude\'s N/A Honda S2000 motor is; if you go up against 900+ pushrod ponies and 750 pounds of earth-shaking torque with a wrong-wheel-drive econobox, you\'re gonna get a fast and furious old-school ***-whipping.\"
              So like i originally asked, i know what the big 3 are, but where do i go from there?
                I know getting rid of the braided ground straps with 4 guage battery wire will help...
                New:04 GMC Sierra 1500 RCLB 4x4 5.3 GU80 3.73\'s.<br />Truck pics<br />Mods<br />Go fast: Panel K&N filter and soon SS truck catback.<br />Appearance: Stull Billet grill,Weston Chrome step tubes,Rhino Chrome hitch step,ARE painted fiberglass cover,Silver star lighting.
                  Did you check in Stereo/Electronics? you may get better feedback in that section.
