Easiest way to get more Hp? - FirebirdV6.com/CamaroV6.com Message Board
This topic is closed.
  • Easiest way to get more Hp?
    Hi I have a 1997 Camaro Rs Fully loaded 30th anniversairy, so far i have a Flowmaster American Thunder 3.5 inch kit on it, with a SLP Cold air Intake system. Now I want some more Hp which would the easiest way to go im interested in superchargers??? any ideas? wanna make this v6 take all the 8's haha and i got the cash to do it
    7
    Supercharger?
    100.00%
    7
    Other Motor Mods
    0.00%
    0
    The easiest is a moderately sized dry nitrous shot. Goes on fast.
      not at all advanced
      easiest mod for more power, sel lthe car, buy an older V8 car
      however if you want to keep the car, a dry shot is by far the easiest way to make lots more power cheaply
      -Aaron, AKA ATL2001<br />93 3.4L <br /><a href=\"http://www.ilfba.com\" target=\"_blank\">www.ilfba.com</a>
        well if you got the money let me piss off your wife and starv your kids
        Cryo treat EVERY THING after you have it
        buy these things
        7:1 c/r psitons (forged of coures)
        4.1 crank (forged DUH)
        sleave the block.. i think you can get like 4.3 bore if you do
        take the heades off port till you hit water fix it then make it glass
        your cam should be set for turbo/nos
        BFT (BIG FU(KING TURBO)
        F.A.S.T will be needed
        fuel injectors http://www.racetronix.com/17113744FM.html
        MSD for spark
        NGK plugs
        bad *** fuel pump
        custom headers for the turbo
        theres your motor don't feel like typing the rest out
        run about 25PSI and a 200 wet shot, thre you have it.
        www.turbov6camaro.com
        1997 3800 Series II Camaro
          You wanna do 8's, I got info for ya.
          1. To hell with the turbo. At that point, you need to contact Whipple for a twin screw SC.
          2. Your car will no longer be streetable. I cannot see an 8 second 3800 Series II on the street, I don't think it is possible.
          3. If you want 8's, its gonna cost. Its gonna cost more than anyone I know to have ever put into a V6 F-body. I am guessing in the $50,000 - $55,000 range.
          4. You would have to lighten that car to the point of no return. No stereo, no AC, no wipers, no interior, no dash, no console...basically, anything bolted, riveted, screwed, glued, and attached to that car that doesn't offer some sort or performance edge to the car, or that is not availiable in a lighter form will have to come off. Only thing that should be in the interior of the car is gauges, one seat, one belt, a rollcage, fire extinguisher, and you.
          Want more info, email me and I can send you an UPDATED price sheet. That is where you are going to have to get started.
          1995 Pontiac Firebird
            I think he meant he wants to be able to beat V8s. ;)
            Matt
            1998 Mystic Teal Camaro M5
              if a viper can run a high 7 and drive home im sure our v6 can do it
                You're right, I thought he said he wants to put it IN the 8's, not TAKE the 8's.
                I could still help ya there too. ;)
                  this thread does not belong here.
                    All three threads are so redundant. This is getting to be a little over the top.
                    1997 Dodge Viper GTS
                      First thing you need to buy.. is a clue.
                      00\' firebird v6 5spd<br />201rwhp ---- 230 rwtq<br />\"Everyday I grow stronger...and further from you.\"<br />WARNING: Do not take any of my comments seriously unless they are technical in nature and then only at your own risk
                        FORCE FED FABRICATIONS has a nice turbo kit. Might check it out... Everybody well tell you something diffrent on how to get more HP. Just look into things and decided for yourself. IMO
                        Purple \'95 A4 RS...Totaled in \'03 23,000 on her :( Red \'95 Camaro M5...A Few Goddies!<br />84 Chevy 6.2L Diesel 4x4 10in. lift 38x15.50\'s<br /><a href=\"http://www.geocities.com/heartland_heat_v6\" target=\"_blank\">Heartland Heat V6</a>&lt;~Member
                          You could just delete two threads and the one left over would be basicly the same, dosen't matter which one, don't be a whore.
                          I speak the truth, I say what other don\'t say.<br />I am a ***.
