Hey guys,
I was wondering if there is a standalone aftermarket pcm they make for our cars. Instead of buying a 97 pcm , and a tuner, it would be much easier to just put a whole new computer in it.
I've already searched, with no luck except for plug in modules.
Have you guys heard of these?
Thanks alot,
Ron
1996 Pontiac Firebird<br />Flowmaster Exhaust, Custom Cold Air Intake, 3.42 gears with LSD
THey made me a custom programmed pcm. It is a good one too. they have a fleet of 10 second w-bodies, so I trust them to program right.
Shipped to my door, it was about $360,+ a 100 core charge for my old pcm.
I had them put in a "dual mode" feature, which is really cool. I have a switch wired through the IAT. when the IAT is working normally, I get my usuall programming benefits. When I flip the switch, I routes the IAT through a 480ohm resistor. When the computer sees this resistance, I pulls out 15* of ignition timing when the TPS is above 68%. This allows me to use nitrous despite my aggresive NA tune. I guess I could theoretically use cheap gas too; but I haven't tried it.
1999 red camaro v6 M5: with a turbo<br />13.52@107.99<br />No, seriously: Who Farted? <br /><a href=\"http://www.cardomain.com/memberpage/600086\" target=\"_blank\">http://www.cardomain.com/memberpage/600086</a>
True standalone systems, like the ACCEL DFI systems, are a helluva lot of money (about 2 grand), a helluva lot to tune, but once they are tuned, they work amazing.
