Which of these 4 cams? - FirebirdV6.com/CamaroV6.com Message Board
  • Which of these 4 cams?
    ok..out of all cams i think i've narrowed it down to 4 that i would really possibly get..which one would you recommend for me..my mods are on my site and id be running a 75 - 100 shot..just doing cam or can with springs/retainers..
    1) ZZP GT1
    2) Intense 1X
    3) ZZP VS
    4) ARH Turbo
    definatly get springs if you get a cam so you can get up to the higher rpms where the cam makes power. id say get whatever one is the biggest :-p.
    \'99 SSM Camaro V6 M5<br />(mod list on cardomain site; too long to list here)<br /> <a href=\"http://www.cardomain.com/id/v6cam99\" target=\"_blank\">http://www.cardomain.com/id/v6cam99</a>
      yeah..right now..personally..im stuck between the GT1 and the Intense 1X
        get the gt2 with springs and pushrods, get a vid with nitrous and that cam setup, gonna sound damn sexy
        2000 3.8 Camaro M5<br /><br /> <a href=\"http://www.cardomain.com/ride/832316\" target=\"_blank\">http://www.cardomain.com/ride/832316</a>
          if it needs a new block..the cam swpa will be nothing because the long block will be sitting there on the floor out of the car..the guy said it would be about an hour to switch cams..
          how much time would it take to change springs, retainers, and rods??
            I wouldnt take any longer as you have to take them off to swap cams. So they would just put the upgraded parts back instead of the stock ones. I think I would get the GT cam, but I dont know much about nitrous. [img]smile.gif[/img]
            [ August 11, 2005, 10:56 PM: Message edited by: RedFrk13 ]
            92 S10 3800 A4(96)<br />1/4: 14.374 @ 92.25 w/ 1.976 60\'<br />Turbo and 12\'s Coming Soon!
              either of the GT cams look nice.. AZ3.8Camaro had good results with what was basically the GT2 and a dry 85 shot and he just did the cam and springs ..now im leaning towards one of the ZZP GTs or the Intense blower cam cuz of it's larger LSA
                X-P Hot Cam!!!!!!!!!!!!!!!!!!
                2001 Firebird 3.8L V6 M5,<br />It once had....<br />NX Nitrous Wet Kit, ZZP X-P Hot Cam, <br />3.42 LSD, Pacesetter Headers, <br />36# Injectors, HP Tuners<br />322 RWHP, 379 RWTQ<br />13.596 @ 102.56 w/100 shot
                  I'm happy with my GT2 cam thus far. Moved the power band WAY up...I really need tuning because at the stock WOT shift point of 5600, the cam is just getting wound up around 5k.
                  I can't wait to spin it to 6500rpm.
                  -1999 Camaro Coupe 3800 Series II V6 A4 - SOLD<br />-1998 Pontiac Grand Prix GTP coupe
                    Originally posted by RedFrk13:
                    </font><blockquote>quote:</font><hr />Originally posted by 1DangerousV6:
                    I wouldnt take any longer as you have to take them off to swap cams. So they would just put the upgraded parts back instead of the stock ones. </font>[/QUOTE]Uh, not exactly. Only the pushrods have to be removed to swap the cam. Retainers and springs are extra work. ;)
                    I will agree with Art, though....go with the X-P Hot Cam!
                    But whatever you do, run far away from Intense.
                    Matt
                    1998 Mystic Teal Camaro M5
                      Yeah, I wasnt thinking when I posted that. [img]graemlins/twak.gif[/img]
                      The xp cam seems good for the nitrous, but will need to run zzps modified retainers because the lift is over 515.
                        i was looking at the xp cam with springs/retainers..but im concerned that because i run a dry kit..i wont be able to supply the fuel or that my injectors wont be enough..i know Art had to increase his injectors but he runs a wet kit..i currently have 30# injectors
                          [img]graemlins/bowdown.gif[/img] [img]graemlins/bowdown.gif[/img]
                          God I love the idle. Plus it will be better for N20 than the GT cams or the 1X cams.
                          If your still stuck, GT2 with a converter if your an auto. If your manual, no worries.
                          1999 Grand Prix GT<br /><br /><a href=\"http://www.fishsgt.com\" target=\"_blank\">www.fishsgt.com</a><br /><br />Best ET: 14.94@91.25MPH with a 2.2 60\"
                            gt2 for turbo? with torque converter?
                            x-p hot cam suck up gas?
                            [ August 15, 2005, 09:54 PM: Message edited by: slow6 ]
                              No. I do believe Zooomer says the GT2 cam wont really be optimal for a turbo. Stattama makes turbo cams.
                              From what I read on other forums, the XP cam will still give you decent gas mileage if you stay out of high rpms. (basically, dont drive like an ***. :D )
