Any significant problems with lowering idle? - FirebirdV6.com/CamaroV6.com Message Board
  • Any significant problems with lowering idle?
    Just curious if their are any significant problems to lowering idle?
    on average target idle is around 700-900 rpms...
    i was wondering if there woudl be any downfalls to lowering to ~500-600 rpms
    Just seems on average might save a little gas, and keep temps down a bit.
    Or do you think we might run into problems iwth the cooling/charging systems?
    Just a half assed thought I came up with while browsing hptuners [img]smile.gif[/img]
    your gong to run ito a lot of problems:
    Low oil pressure
    Low charging voltage
    Fighting the idle
    Low power on take off
    Vacuum fluxuations (sp)
    Idle dipping when coming to a stop.
    It's not going to save you any gas milage really at all. I mean unless you sit the car at idle for 3 or 4 hours. Temps will also act just as they did before. It's not going to make any difference. really there isn't any good reason to drop your idle.
      He just wants his car to lope like mine. [img]tongue.gif[/img]
      Matt
      1998 Mystic Teal Camaro M5
        well I will admit that wsa in the back of my head [img]smile.gif[/img]
          lope =/= stumble ;)
          lope has meaning, stumble means you have problems.
