I just recently built my motor and everything runs awesome! BUT there is a slight problem i came into. WHen the engine is running it pulls a vacuum on the darn valce cover. when i take the oil cap it is sucked down and i have to pull slighty to get it off and you can hear the sucking noise as it coimes off. then i can hold my hand over the place you put oil and after about 10 seconds it has a suction to it. what is this caused from?
VERY VERY odd problem with engine!!!
huh? you taking your oil cap off when the car is running?? why??
naturally aspirated engines run at vaccum that's what makes a bunch of the stuff like the brake booster work. Not trying to be an Azz but your post is consfusing. Please use spell check.-Brad
2000 V-Star Custom 1100
:rock:
Originally posted by black98V6:
naturally aspirated engines run at vaccum that's what makes a bunch of the stuff like the brake booster work.Matt
1998 Mystic Teal Camaro M5
I would have to look at the PCV system but "most" GM motors WILL have vacuum at the oil fill.1996 Silver camaro Z28. M6,<br />12 bolt, 4.11\'s, posi, Rear cover, Spec stage 2, loudmouth, more <a href=\"http://home.mainstreamtopics.com/?index=3&module=1\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=1</a> <Mods, Pics & more <a href=\"http://home.mainstreamtopics.com/?index=3&module=2\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=2</a> <Fbody Tech Articals
