Thanks guys.. I forgot to mention that this error came up when the laptop was NOT hooked up to the car. So maybe the software got a misreading? who knows.. I'll contact them today.
I'm using Windows XP. I think that error came up because I didn't start the car first and then run the program. (I tried to open the program and then start the car).
is the dos version better? what do you need to read it if you have the dos version? does the windows enhanced version actually work properly? please keep us updated
Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
