Knock sensor bypass??? I did a search for this but found nothing. I was wondering how it is preformed. Is there something you have to buy or is it a "free mod"? Also I know kinda what it does but can somebody explain it all the way for me? Thanks.
Knock Sensor Bypass
Knock Sensor Bypass
1995 Camaro<br />3.4 Engine<br />5 Speed<p>PERFORMANCE: 3 Inch Cat, 3 inch Flowmaster American Thunder Cat Back, 3.42 Gears, Jet Stage 2, Low Temp T-Stat, K&N CAI, ASP Pullies, TPS Enhancer, MSD Wires, Free Mods.<br />APPEARANCE: Z-Roc Hood, Chrome 5 spokes, Custom Emblems, LGMotorsports Wing.<br />BEST TIME: 15.7 @ 92.1<p>GO ARMY!Tags: None
over at ls1tech.com a guy makes dampeners for the knock sensors.. helps reduce FALSE knock..
I don't recomend it though.
How do you have knock?
If you unplug the knock sensors, it will report that to the PCM and the PCM will pull tons of timing.Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
I dont have a knock at all. I just heard of this and was wondering what it is.1995 Camaro<br />3.4 Engine<br />5 Speed<p>PERFORMANCE: 3 Inch Cat, 3 inch Flowmaster American Thunder Cat Back, 3.42 Gears, Jet Stage 2, Low Temp T-Stat, K&N CAI, ASP Pullies, TPS Enhancer, MSD Wires, Free Mods.<br />APPEARANCE: Z-Roc Hood, Chrome 5 spokes, Custom Emblems, LGMotorsports Wing.<br />BEST TIME: 15.7 @ 92.1<p>GO ARMY!
