99 to 2001 PCM Swap........ - FirebirdV6.com/CamaroV6.com Message Board
  • 99 to 2001 PCM Swap........
    Is there anything I should know before I do this swap or do I just plug and play type of thing. the 2001 PCM is already programmed allthough I am not sure what gear ratio its programmed too.
    Eric
    Eric
    2005 Mustang 4.0
    1996 Camaro Conv
    2000 Ford Excursion
    "Darkness Falls"
    Plug and play but do the crank position sensor setup before starting her.
    2002 5-spd NBM Camaro
    Details: www.1lev6.com
      <blockquote>quote:</font><hr>Originally posted by Dominic:
      do the crank position sensor setup before starting her.<hr></blockquote>
      whats that?
      -Marc
        It's called a CASE learn, you have to do it any time you put a new PCM in the car. The PCM has to learn the crank position sensor on that motor, the cps timing will be just a little bit different on every engine.
          <blockquote>quote:</font><hr>Originally posted by merlinsrealm:
          Eric
          <hr></blockquote>
          Also if you run a 160 stat the 2001 will not like it and you'll need a resistor from me.
            Merlin where did you get the 2001 pcm? I want one too, I have a '99 and can't do crap with that pcm.
              <blockquote>quote:</font><hr>Originally posted by Dekay:
              Merlin where did you get the 2001 pcm? I want one too, I have a '99 and can't do crap with that pcm.<hr></blockquote>
              http://www.tacreationsusa.com/
              His name is Brent and he is very helpful. I know some other people on the forum have talk to him from time to time.
              Eric
              Eric
              2005 Mustang 4.0
              1996 Camaro Conv
              2000 Ford Excursion
              "Darkness Falls"
