Didnt somebody install a 224/224 Comp Cam in a 3.8? I remember while back reading that but I cant find anything. Just curious how it worked out.
224/224 Cam
I will probably go with 224/224 112 for my 12 sec NA car...
I do not recomend that cam for a typical setup.. To use such a big cam in an NA application you will need at least 4.10's, 4500 stall, spin to 6800 and a light car due to the loss of low end tq and increase of high end HP.
Thats my theory so far.Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
Dan Taylor installed that cam in his Grand Prix GT (3.29 gears)
He ran 15.4 before the cam swap and 15.4 after the cam swap. Following that he installed a high stall converter and ran 14.8, right now that cam appears to be too large for most cars. His rev limiter was at 6400 BTW.
Very interesting info!!! Thanks Zoomer, I'm going to shoot him an e-mail.Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
Here's a link of a GT with a 224/224 112 +4
http://www.charlesbeyer.com/carstuff/wifeSE.jpg
Thanks Zoomer for the link.
Restricted intake and exhaust.. I'll try to get more info.
This is what I gathered.
It's a thrasher grind. 224/224 112 with 2 degrees of advance. .566/.566 lift.
Car has trouble idleing. Low end torque is gone.
[ November 07, 2002: Message edited by: Magnus ]</p>Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
hmmm.... i know i have a diff type of cam and i don't have as much lift just wanna be sure i won't have probs.
226/236 .494/.506 112ls
but like i said it's a hydraulic flat tappet cam my air flow has been opened up alot to run this cam i think i will be fine just wanted to see what you all think1998 Jet Black Trans-am M6 T-tops<br />\"Ask, and it shall be given you; seek, and ye shall find: knock and it shall be opened unto you:-Matthew 7:7<br />Old car<br /><a href=\"http://matthew27529.tripod.com/getsome\" target=\"_blank\">http://matthew27529.tripod.com/getsome</a><br />NEW CAR<br /><a href=\"http://garnerebel.tripod.com/\" target=\"_blank\">http://garnerebel.tripod.com/</a>
So what are the reasons why a cam would be to big for our 3.8 and what could we do to change that is it possible to have a 220/224 cam in a 3.8 and get good results? Or would that yield crappy results? .500 220/224 114lsLongtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
<blockquote>quote:</font><hr>Originally posted by SLOWBRAEATER:
So what are the reasons why a cam would be to big for our 3.8 and what could we do to change that is it possible to have a 220/224 cam in a 3.8 and get good results? Or would that yield crappy results? .500 220/224 114ls<hr></blockquote>
When you increase duration and lift it raises the power curve. And with a 224/224 cam it will raise the peak power range above 6k. so it might make more power if you can rev really high but it wont make enough usable power.
I was thinking maybe if it were possible to run a stroker 3.8 which would bring alot of the power down to lower rpm's we could run a huge cam and not have to rev very high. But I dont think I would ever spend all that money to stroke a 3.8.
<blockquote>quote:</font><hr>Originally posted by Magnus:
Thats my theory so far.<hr></blockquote>
I might try a similar setup now since I got some money to burn.
Anything over 212 intake is overkill for 6000-7000RPM range on our cyl sizes.
Its simple math to figure the intake duration calcualtion. Lift however is determined by head flow data, and 0.45-0.5 is plenty.2002 5-spd NBM Camaro
Details: www.1lev6.com
<blockquote>quote:</font><hr>Originally posted by Dominic:
Its simple math to figure the intake duration calcualtion. Lift however is determined by head flow data, and 0.45-0.5 is plenty.<hr></blockquote>
Magnus tends to think that you're wrong and he's right so he is going with 224/224.
[ November 12, 2002: Message edited by: Scott Black ]</p>
Show the math.
Scott, what the heck is your problem? Why are you starting crap again?
I do agree that more than 212 NA might not be the greatest idea for the average joe.
An average joe with the 224/224 112 cam went 91mph at the track with PCM tuning while other averages joes went 92mph with much less cam.
You REALLY need a wild setup for a wild cam or it just won't work well at all.Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
Is that desktop dyno????
What do you think about the exhaust duration and lift??? Just curious...1997 Chevrolet Camaro v6 - 13.8@104MPH
1997 Dodge Viper GTS
I disagree with dominic that anything over 212 is overkill, i think my cam is cool for my car i also have a 3600 stall and 3.73s but i think my cam is just fine i will have numbers in march. Do any of you guys think my 220/224 cam is to big ? Like i said i am running a 3600 stall with 3.73 might be going to 4.10 but uncertain at this point, i will be running a direct port shot and i hope this cam will be cool for n/a as well, I will have my rev limiter raised some as well.
[ November 12, 2002: Message edited by: SLOWBRAEATER ]</p>Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
