I'm building up a motor for direct port nitrous, and i want a cam that will help that along, but i also want it to run smooth,on cold start ups and be able to idle, without dying, im porting the t/b,heads,and intake too, if that makes a difference.also will a good n/a = a good nitrous cam, if not what would the diff. be?
Nitrous and a daily driver, what cam???
Msd wires,Summit coils,Cuctom CIA&longtubes 2.5inch w/side exit,Cam,Heads & Intake,30# injectors,reprogrammed computer,3400 edge Converter, 3.73\'s&LSD,Edlebrock torque arm, SLP LCA\'s,Jegs panhard bar,16 inch nittos Best ET 14.374 @94 <br />Best 60\' 1.91Tags: None
do you have those specs? if so, how does your car do for idle, and cold startups?, and does it help even if your not sparying? did you have crower do it?Msd wires,Summit coils,Cuctom CIA&longtubes 2.5inch w/side exit,Cam,Heads & Intake,30# injectors,reprogrammed computer,3400 edge Converter, 3.73\'s&LSD,Edlebrock torque arm, SLP LCA\'s,Jegs panhard bar,16 inch nittos Best ET 14.374 @94 <br />Best 60\' 1.91
