How much tension should there be on the timing chain??? I just pulled my cover off and the chain is very loose...I guess its a good thing its being replaced
Timing change tension?
Ben<br /><br />1995 White/Black 3.4L<br />As far away from stock as possible<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=288292\" target=\"_blank\">My Site!!!</a><br /><a href=\"http://www.redlinevsix.com\" target=\"_blank\">RedLineV6</a><br />Rebuild and 3.4 T70 Turbo is complete<br />Details to come....Tags: None
Haynes manual says 1" of play max.1994 Firebird 3.4<br />15.65 @ 86.8<br /><a href=\"http://www.funkz.net/firebird.htm\" target=\"_blank\">funkz.net/firebird</a><br /><a href=\"http://mywebpages.comcast.net/funkz/timeslips.htm\" target=\"_blank\">Timeslips</a>
ya its being replace with a cloyes double roller chainBen<br /><br />1995 White/Black 3.4L<br />As far away from stock as possible<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=288292\" target=\"_blank\">My Site!!!</a><br /><a href=\"http://www.redlinevsix.com\" target=\"_blank\">RedLineV6</a><br />Rebuild and 3.4 T70 Turbo is complete<br />Details to come....
when you put the new one on, you will be fine.- Josh<br />If you have any questions or need installation pics/help, e-mail me: Viper98885@aol.com<br /><a href=\"http://Camaroz28.cardomain.com/id/viper98885\" target=\"_blank\">\'93 Camaro Hardtop</a><br /><a href=\"http://Camaroz28.cardomain.com/id/01lincolnls8\" target=\"_blank\">\'01 Lincoln LS8 Sport</a><br />\'00 Yamaha YZF-R6<br /><a href=\"http://www.ftpp.net\" target=\"_blank\">Full Throttle Performance</a>
Originally posted by White95:
ya its being replace with a cloyes double roller chainJordan<br />15.09@90.7<br /><a href=\"http://www.fullthrottlev6.com/forums/vbgarage.php?do=view&id=21\" target=\"_blank\"><b>1995 Camaro 3.4 M5</b></a>
I know you need a pully puller and installer. Its pretty straight forward just take the water pump off and there should be another cover bhind that. That is your timing chain cover pull that off and there is your chain. I don't know on the 3.8 but on the 3.4 engine you have to take the power stering pump and tensioner just to get the water pump off and possibly more to get the timin chain cover. Its a pretty simple job just time comsuming. And if you gonna replace the chain replace the sprokets along with it. No since in ****ing you engine up over another 10 or 15 buck part.
you don't have to remove the power steering pump you just have to unbolt it from the bracket..pretty much plan on removing or unbolt all your accessories to make you life MUCH MUCH similar....i have pics in my sig if your curiousBen<br /><br />1995 White/Black 3.4L<br />As far away from stock as possible<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=288292\" target=\"_blank\">My Site!!!</a><br /><a href=\"http://www.redlinevsix.com\" target=\"_blank\">RedLineV6</a><br />Rebuild and 3.4 T70 Turbo is complete<br />Details to come....
