I took off the driver side valve cover and watched and noticed the first valve the guide was all the way up on the valve stem hitting the inside top of the valve spring with every revolution of the motor.
I AM SO HAPPY!!! After so long i know the problem
Originally posted by slacker69: I took off the driver side valve cover and watched and noticed the first valve the guide was all the way up on the valve stem hitting the inside top of the valve spring with every revolution of the motor.
:eek: how did you not drop the vavle ?
Im sure the valve is in place cause seal is still stuck on the valve just has the broken valve guide with it. as well as the retainera
