I think i have discovered my KR problem - FirebirdV6.com/CamaroV6.com Message Board
  • I think i have discovered my KR problem
    Lately i havent been able to run anything other than stock settings on my Maft+ any other setting i get knock so i hooked up a little fuel psi guage to my fuel rail and im only at 35 psi at idel and when my friend rev'ed the car the fuel psi actully dropped down to 32 any clues please let me know.
    <b><a href=\"http://www.sick-sixx.com\" target=\"_blank\">SICK-SIXX MEMBER</a></b><br />NA 14.345 with a 1.863 60 foot<br />Nitrous 13.03@99.5 with a 1.63 60 foot<br /><br />2000 Camaro 3.8L A4: USE TO HAVE Comp Cam 210/220 .535/.547 113lsa 111 I/C, Port and Polished Heads, NX Wet Kit 100 Shot, CPRA made by CP, RK Sport Headers
    dying fuel pump.. happened to me..
    As it got worse, I would see 32 at idle and 21 at WOT.. man that was horrible..
    Walbro 255 in-tank and I have 100% confidence in my fuel delivery needs. [img]smile.gif[/img]
      will this make me get KR i cant advance timing or anyhting
        Yes, you will see KR until you put in a new fuel pump. Your fuel supply is inadequate, you are running lean, hense the predetionation of the air/fuel mixture. Predetionation is one of the major causes of real KR.
