Is there any way to make my own cable for AUTOTAP? I have a cable that came with a Hypertech programmer, looks like printer cable on one side and on the other side it is ODB2 connector. Is this the same type of cable autotap uses?
Making a AUTOTAP CABLE?
Autotap uses the same one but it uses a DB9 serial outlet.
the hypertech purposely chose the DB15 so you couldnt use it for that reason.
If you look under your dash, the OBD2 connector actually only uses 4 wires (power, ground, tx, rx).
:D2002 5-spd NBM Camaro
Details: www.1lev6.com
You need J1850 to RS232 translation box. Check out the VPW section on the OBD Hacking UBB:
http://pcm.dxsoftware.com/forum/
[ January 15, 2003: Message edited by: Magnus ]</p>Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
My head hurts from going through that board...I know alot about computers, but this stuff is way outta my league...someone wanna give me a quick run-down on how to do some of the **** they're talkin about...I got the OBD-2 cable and software, can I even do anything with that, cause I know theres one screen on obd-2 that I dont know what it does....maybee something like this? ....so confused
05' CTS-V
00' Camaro - SOLD :(
I was wondering u know how EFlive has the bi directional cable whould there be any way to use that cable and then send and flash the pcm from that.<b><a href=\"http://www.sick-sixx.com\" target=\"_blank\">SICK-SIXX MEMBER</a></b><br />NA 14.345 with a 1.863 60 foot<br />Nitrous 13.03@99.5 with a 1.63 60 foot<br /><br />2000 Camaro 3.8L A4: USE TO HAVE Comp Cam 210/220 .535/.547 113lsa 111 I/C, Port and Polished Heads, NX Wet Kit 100 Shot, CPRA made by CP, RK Sport Headers
Slacker, I believe so.. Post that question in the VPW section of the obd hacking board.. Paul of EFILive frequents the board. He may be able to help you.Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
