ATTN: Magnus...smart guys..fuel pump Q - FirebirdV6.com/CamaroV6.com Message Board
  • ATTN: Magnus...smart guys..fuel pump Q
    http://cgi.ebay.com/ebaymotors/ws/eB...ME:B:EOAB:US:6
    ac delco part# ep286 or gm part# 25117086
    I purchased that pretty blindly because it was cheap and I found it with literally like 2 minutes left, but I know that our stock ones flow at 48-55 psi, and this new flows up to 95psi, but don't go by my numbers, I can't confirm them, just going by what the auction says. Let me know if you think I made the right decision, ect for my turbo setup running 6psi for now and then 9psi with better tuning.
    Thanks guys, Sam
    My honest oppinion..
    It will do the job yes.. however I'm not to fond of external fuel pumps. They are louder, and still have to pull fuel THROUGH the internal pump.
    The price is VERY nice though. You'd pay about double that for an internal pump and then have to go through the hassel of dropping the tank.
    Mike huff uses external pump and is happy with it.
    I use internal and LOVE it.
    Cons to external:
    Louder
    Have to pull fuel through restrictive stock pump
    Pros to external:
    Usually more powerful
    Cons to internal:
    Have to drop the fuel tank to change it
    Pros to internal:
    Quieter
    Replaces weak and restricte stock pump with much better one.
      So is there no way to remove the stock pump? Even if it involves dropping the tank- yeah a pain in the *** but if it's worthwhile... definately doable.
      Sam
          <blockquote>quote:</font><hr>Originally posted by xjarayax:
          ^<hr></blockquote>
          What else do you want? God has spoken. You got your 10 commandments now go spread the word.
            Uncalled for Scott.
            You need the stock pump in there for a pickup feed I believe.
            I would really just sell that external one and pick up a walbro from autoperformanceengineering..
            or ask Mike Huff about his external.
              <blockquote>quote:</font><hr>Originally posted by Scott Black:
              <hr></blockquote>
              :rolleyes:
              1997 Dodge Viper GTS
                <blockquote>quote:</font><hr>Originally posted by Magnus:
                <hr></blockquote>
                Cons - NOISY! My external pump is very noisy. It came with my blower and was a quick and easy install to fix my fuel pressure issues. I have plenty of fuel now even with the blower and nitrous together. I'm sure eventually the stock pump will die so I have a Walbro intank pump waiting on the shelf.
                Michael Huff<br />92 RS, 98 V6, 97 SS, 00 Z28 <br /> <a href=\"http://www.carolinafbodyclub.com/\" target=\"_blank\">http://www.carolinafbodyclub.com/</a>
                  <hr></blockquote>
                  [img]graemlins/thumbsdown.gif[/img]
                  <b>99 Trans Am- Bright Red 6 speed</b><br /><br /><a href=\"http://thunderracing.com/projects/?action=read&pgid=86\" target=\"_blank\">348ci forged shortblock, Thunder Racing ported 5.3l heads, Cam Motion 246/250 110lsa hyd. roller cam, Moser 12-bolt (4.56/spool)</a><br /><br /><b><i>10.32@131.70, 1.43 60\' - 3238 raceweight, +675\' DA</b></i>
                    5 days ago
