PCM upgrade options inside - FirebirdV6.com/CamaroV6.com Message Board
  • PCM upgrade options inside
    Well I just called my local Chevy dealership(Scoggin-Dickey) to ask about a price on a HHP3. He informed me that he was working on closing a deal with Super Chips which also has a programmer much like the Hypertech for my car, I was just a little shocked. So now we have 6 options correct?(some 98+ some 2000+)
    1. Jet Chip
    2. Hypertech
    3. ASE Chips
    4. Super Chips
    5. Custom Programming
    6. MAF Translator Plus
    I know that Super Chips and Hypertech are about the same things but Super Chips might be a little cheaper. I already have the Jet Chip and know what little that does. I'm actually wanting to switch to the HPP3 to raise my rev limiter and take off the top speed govener. Can we get a post with detailed information with what exactly each of these does and maybe put this information in the Modifications Encyclopedia?(ok, just found it in there, I was thinking more detail than "Blah blah blah")
    [ November 18, 2002: Message edited by: Ttop34 ]</p>
    1997 Nassau Blue Vette<br />1989 Jeep Cherokee 4x4 (lifted with 31\" tires)<br />2000 V6 Camaro, loud, cammed 210rwhp *SOLD*
    98-99 have no programmer that I know of that can take care of shift points and gear/tire changes. Custom (read ****ing expensive) programming is the only option. It would be nice if this programmer worked on 98-99 models. Is that the plan?
      Actually Jet has stuff for the 98-99. It has the Jet Chip would messes with advancing the timing and a few other little things, then the SCU2000 (Speed Control Unit) to correct speedometer calibration for vehicles where tire size or gear changes are required, changes transmission shift points and eliminates the top speed limiter. www.jetchip.com
      Also the MAFT+ is for all years and better than the Jet Chip.
        I have had superchips custom programming in for many years so far.
        When I did it they could adjust timing, fuel mixture and remove speed limiter.
        I kept the timing stock, limiter removed and they adjusted my fuel mixture accordingly.
        My bird is doning fine for many years
        1997 bird
        Keep us updates please
        [ November 19, 2002: Message edited by: 12secondv6 ]</p>
          <blockquote>quote:</font><hr>Originally posted by Ttop34:
          <hr></blockquote>
          I believe the SCU2000 only allows for gear changes in two increments. So 3.08 to 3.73 guys like me are stil out of luck.
            How could they adjust fuel accordingly when each car acts different on and off nitrous, i was under the impression the only way to see what the car is actually doing is to have autotap and a laptop or some sort of software? Man to bad you couldnt have gotten your rev limiter raised so you could run a higher numerically gear such as 3.73 and not hit the limiter, zooomer says he can do trhat so we can run a huge gear on and off nitrous so we get the full affect from the gears and nitrous so that is very cool
            Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
              <blockquote>quote:</font><hr>Originally posted by SLOWBRAEATER:
              How could they adjust fuel accordingly when each car acts different on and off nitrous, i was under the impression the only way to see what the car is actually doing is to have autotap and a laptop or some sort of software? Man to bad you couldnt have gotten your rev limiter raised so you could run a higher numerically gear such as 3.73 and not hit the limiter, zooomer says he can do trhat so we can run a huge gear on and off nitrous so we get the full affect from the gears and nitrous so that is very cool<hr></blockquote>
              Well, they send out a form and you list any and every mod you have under the sun.
              They adjust accordingly from past experience.
              I am not the first v6 they have done.
              Rev limiter raised? Why would I need that?
              So far with my 323 gears and taller 26.1 inch et streets no one has touched my 1.630 60 foot
              I don't need more gear
              My car came stock with 308 gears.
              I run 323 gears
              I run a 26.1 inch tall tire and to the ground it is like having 308 gears so I do not need to have anyone reprogram it.
              I think I am doing quite fine with my weeney 323 gears.
              Have YOU had your computer reprogrammed by mr zoomer?
                <blockquote>quote:</font><hr>Originally posted by 12secondv6:
                1997 bird
                <hr></blockquote>
                Superchips turned me down.
                  How much does Superchips charge to do that?
                  1997 Camaro,<br />SLP cold-air, Hooker Supercompetition catback, Air temp. module, Powerstat thermo, 1LE Aluminum drive shaft, 3.42 POSI rear, 1LE sway bars front & rear, Powerstop crossdrilled rotors on all corners, Torque Thrust II\'s (17x9.5 front & 17x11 rear), and a couple other goodies. <a href=\"http://www.villagephotos.com/pubbrowse.asp?selected=84487\" target=\"_blank\">http://www.villagephotos.com/pubbrowse.asp?selected=84487</a>
                    <blockquote>quote:</font><hr>Originally posted by PiLOTLiTE:
                    <hr></blockquote>
                    wont change the shift points
                    Visit My F-Body Page
                      A few months ago I saw an ad for super chip in a mag. about a tuner for the 3.8 v6 camaros and firebirds but when I called them they said they were working on and couldn't give a time when it would be out. This was like 7 or 8 months ago.
                      40th Ann GTp 4door
                        Well, talked to the guy at SD again today and he said he should have the deal wrapped up in a couple of days to become a Super Chips Distributer. The price should be about the same as the HPP3 but the power gain should be slightly more.
                        I'm not sure if their just going to claim more or actually make more, but I might have to get that instead of Hypertech if it does.
                          isn't super chip owned by Jacobs Electronics out of Midland Tx. now?
                          40th Ann GTp 4door
                            just let me know when theres a HPP3 for 98's or the superchip programer for 98's
                            My ride: <br /><a href=\"http://members.cardomain.com/youngdeezy\" target=\"_blank\">http://members.cardomain.com/youngdeezy</a><br />98 Firebird 3.8L A4<br />Mods:80 seires flow master muffler<br />dual exhaust 3\" pipes,whisper lid<br />k&N filter,3.42 gears and LSD, 180 thermostat, free ram air mod & 1/2\" raised air box + some apperance mods<br />1/4 mile 15.8 @ 85mph<p>I\'ll see you in the traffic...
                              James i wasnt trying to affend you, I never said your gears or anything is weeny, I only suggested that with higher numerically gears and sticky tires i bet your car would fly even faster, even though it is very impressive, I meant no harm in anything i said. I understand everyone has different choises but my choice is to have a greater et rather than a better 60ft than anyone, I mean the et is what counts at the end and magnus is a few tenths quicker, well atleast a few, no harm intended in this either. Im just saying that my choice is greater et sorry if i affended you
                                Still trying to find oil leak
                                1 day ago
                                Getting some work done on my truck
