Cheap way to add knock? - FirebirdV6.com/CamaroV6.com Message Board
  • Cheap way to add knock?
    Any cheap/easy/adjustable ways to add knock and have the car pull timing?
    You could do the IAT resistor mod, but make it think it's really hot for a degree or two. And a potentiometer would allow you to do this with some adjustability. Good luck with your project [img]smile.gif[/img]
      I think your talking about taking out timing right? When knock is sensed, the computer pulls out some timing. (retards0. The IAt sensor is the free mod that will add a little more timing (advanced). Hope that helps. ;)
        Good try, but not completely true. The IAT controls alot of timing. And by adding a different resistor than most do, instead of giving more timing, you can make it take away or retard the timing [img]smile.gif[/img]
        Say the PCM thinks it's 120*, it'll retard the timing.
          Anyone have autotaped values with different resistors? I still have a few floating around from some other electronics I dabble in [img]smile.gif[/img]
            theres a post here some were i seen i seen one person did all the vuales search in gen tech for it
            www.turbov6camaro.com
            1997 3800 Series II Camaro
              also i have been doing some reading you don't want to add knock cause the pcm has a recovery time and you lose a lot of HP, and soo much other stuff
              http://www.fishsgt.com/knock%20retard.htm &lt;&lt;&lt; that link should help you out good read !!!
              [ October 30, 2004, 05:06 PM: Message edited by: viper04af ]
                Yeah, your right, but usually when people do the IAT mod, the put a resistor in that for example makes the PCM think the air is like 32*F. So it advances the timing. A simple rule is, more advance will help your top end. Obviuosly if your advanced it too much (carbed cars with distributors0 the car wont run good anywhere. But it is a fact that the knock sensor will retard timing when it senses knock, to try to rid the engine of that problem.
                  </font><blockquote>quote:</font><hr />Originally posted by OneQuickV6:
                  resistor in that for example makes the PCM think the air is like 32*F.</font>[/QUOTE]nope its 50* F
                    Originally posted by viper04af:
                    </font><blockquote>quote:</font><hr />Originally posted by 93camaro_zzz:
                    resistor in that for example makes the PCM think the air is like 32*F.</font>[/QUOTE]nope its 50* F </font>[/QUOTE]mine I bought one from RKSport a long time ago and it makes it read 36*, i havent used it in a really long time...
                    <b>Black</b> 1998 Pontiac <i>Firebird</i> A-4 swap<br />271.4rwhp/259.4rwtq NA<br />13.30@102.44 <br /><a href=\"http://www.freewebs.com/wickedsix98\" target=\"_blank\">www.freewebs.com/wickedsix98</a>
                      Originally posted by WickEdSix9838:
                      </font><blockquote>quote:</font><hr />Originally posted by viper04af:
                      resistor in that for example makes the PCM think the air is like 32*F.</font>[/QUOTE]nope its 50* F </font>[/QUOTE]mine I bought one from RKSport a long time ago and it makes it read 36*, i havent used it in a really long time... </font>[/QUOTE]weird the ohm i took from someones and made my own siad it was 50* on my car lol
                        Kids, if you simply put in a different value resistor, it will tell te PCM a different temperature. Not rocket science there!
                          yes it is.....
                            yes it is.....
                            Not in Texas! [img]graemlins/rock.gif[/img]
                              yes it is.....
                              Not in Texas! [img]graemlins/rock.gif[/img] </font>[/QUOTE]damn OHIO schools lol
