New Engine Done, Look Inside for Details and Some Info for Other Rebuilders - FirebirdV6.com/CamaroV6.com Message Board
  • New Engine Done, Look Inside for Details and Some Info for Other Rebuilders
    Just got back from my mechanic's place and here's the news on my new engine and what all has/is being done:
    2002 3800 Series II Block / Heads
    Head Valve Job / Cleaning
    Block Cleaned / Bored 0.030 Over
    Sealed Power Pistons / Rings
    ARP Head Studs and ARP 2000 Rod Bolts
    Clevite Trimetal Main / Rod / Cam Bearings
    FelPro Gaskets All Around
    Hot Tanked Intake Manifolds and Front Accessories
    Pacesetter Ceramic Coated Headers / Y-Pipe
    No Cat / Caspers O2 Sim
    This thing is so nice looking I could have crapped myself when I got there. Everything looks perfect! As far as boring it 0.030 over, he said it would be fine as long as I didnt use a power adder which I wont be. Here's the prices for everything from the receipt I got..
    Sealed Power Hypereutectic Pistons ------ $182
    Sealed Power Rings ---------------------- $146
    Clevite Bearings ------------------------ $100
    Fel Pro Gaskets ------------------------- $175
    Cylinder Boring (0.030 Over) ------------ $80
    Press Work (in sets) -------------------- $36
    Valve Job (V6 Heads, pair) -------------- $80
    Miscellaneous Cleaning ------------------ $40
    Disassembly / Reassemble Shortblock ----- $215
    I supplied the other parts such as the headers, rod bolts, head studs, etc. Got them from Intense Racing, ZZPerformance, etc. I will let you all know how it runs come Monday when the engine is in the car and running. Should have some sound clips and video clips too soon after its done, my exhaust setup for reference is:
    Pacesetter Ceramic Headers / Y-Pipe, No Cat / O2 Sim, Hooker 3" Catback Exhaust System
    Have a custom 3.5" mandrel bent jet-hot coated cold air intake too with a green performance air filter.
    1997 Pontiac Firebird 3.9L<br /><br /> - TSP Dyno Tuned<br /> - Bored 0.040<br /> - ARP Rod Bolts / Head Studs<br /> - Custom CAI<br /> - Pacesetter Ceramic Headers / !Cat<br /> - 3\" Catback w/SLP Firehawk Muffler<br /> <a href=\"http://www.cardomain.com/memberpage/649312\" target=\"_blank\">http://www.cardomain.com/memberpage/649312</a>
    that some cheap LABOR :eek: that a good deal
    but may i ask why you did all that and are not running a power adder??? lol
    Diamond coated piston 8.5:1 c/r w/rings and wrist pins
    Forged L32 2004 GTP Connecting Rods
    Intense racing head gaskets
    Comp Cams custom grind,
    Comp cams Hydraulic Roller Lifters
    Comp cams 130lb springs
    Comp cams titanium retainers
    Comp cams push rods
    Cam install kit w/timing chain
    Clevite 77 TriMetal Main Bearings&lt;
    Clevite 77 TriMetal Rod Bearings&lt;
    Clevite 77 TriMetal Cam Bearings&lt;
    Oil PSI kit to 80 PSI at WOT
    New oil pump kit
    long block labor for that was $1780 :eek:
    [ November 01, 2004, 11:38 PM: Message edited by: viper04af ]
    www.turbov6camaro.com
    1997 3800 Series II Camaro
      Well, basically a year ago i picked up a 2002 engine longblock just in case mine died. A month ago it died. When i had the new engine's heads pulled it hadnt been run or anything but there was some rust in the cylinders and the heads needed cleaning and such. So I had the block cleaned and bored (needed new pistons b/c there was rust on them, so I got it bored 0.030 over and got the right size pistons), got the heads cleaned, bought some goodies for peace of mind (arp studs / rod bolts), and had it professionally setup. I want it to run like a champ and run for a while so I put some extra dough into it, plus the labor was... affordable [img]graemlins/rock.gif[/img] I would be glad to give this guy a reference for anyone in GA who wants him to do their work once I get the car back running as he has been awesome all along! Just for information here are the complete totals it will be running me:
      2002 Longblock - $850 shipped, no miles, needed work
      Engine Assembly / Swap - $900
      Machine Shop Labor - $451
      Total Parts Cost - $1100 (includes headers, cleaned injectors, gaskets, new pistons/rings, etc)
      So.. $3300, fully done with plenty of upgrades and professionally installed. Not too terrible overall considering I got a few quotes from GM for over 3K for just the longblock! Although very affordable in comparison to what Im getting, my budget is limited so no cam/heads will be going on anytime soon. Next chunk of change will prob go into a rebuilt tranny with a torque converter, ls1 driveshaft, and an eaton posi 3.42 rearend, eventually....
      [ November 01, 2004, 11:52 PM: Message edited by: cboney2003 ]
        Comp cams push rods
        New oil pump kit
        Viper - was the $1780 just labor for the assembly of those parts or parts and labor together??
        \'01 Mineral Grey SVT Cobra<br />-former F-body owner
          yeah...holy crap...my labor was like $1300...and hmmmmm...i've been spraying and my cylinders are bored .030 over..
            is .020 over to much for a heavy boosted engine??? I hope not. My machince shop quoted me somewhere in the $1000 area. I never thought of getting the accessories hot tanked.....
            Ben<br /><br />1995 White/Black 3.4L<br />As far away from stock as possible<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=288292\" target=\"_blank\">My Site!!!</a><br /><a href=\"http://www.redlinevsix.com\" target=\"_blank\">RedLineV6</a><br />Rebuild and 3.4 T70 Turbo is complete<br />Details to come....
              Originally posted by ellik:
              </font><blockquote>quote:</font><hr />Originally posted by viper04af:
              Comp cams push rods
              New oil pump kit
              Viper - was the $1780 just labor for the assembly of those parts or parts and labor together?? </font>[/QUOTE]yep and a few odds and ends, the new oil pan was 100 bucks lol....
              plus i can back and he hook some stuff on the motor after it was running to scan for anything that could go wrong..... wierd trian noises, checked the compersion and when i left hes like let lose ! :D
                Well 1DangerousV6, thats nice to hear. I definately wont be worrying about problems with it 0.030 over now since Im not using a power adder at all. Way I figure it, my next set of cash will be going into some bolt ons, I'm curious to see how much horsepower this combo will make:
                Increased Bore Size (0.030)
                Mandrel Bent Ceramic Cold Air Intake
                Pacesetter Headers
                No Cat
                Hooker 3" Catback
                Meziere Electric Water Pump
                Aluminum Driveshaft
                SLP 1.8 Roller Rocker Arms
                Should be set up pretty darn well for a highway/topend runner (very free flowing exhaust and some topend horsepower boltons)
                Any guesses to the rear wheel HP/TQ with this setup? I have everything now but the water pump, driveshaft, and rockers.
                  all that and no cam?
                    if you don't have the monye to do the hole the hole motor wait and do it right, your wasting atleast $800 to go back and do the cam later
                      Forget having it bored .030 over. Buy HPTuners software, or drive down to TSP and have them tune it. Add FI and you're in business. You'll be satisfied with it NA for awhile, then you'll want more. In that case, you won't be able to go any farther.
                      1998 A4 Pontiac Firebird
                        Thanks for the support... This car is not a race car, its a daily driver. I needed to fix it, so I did, plus some extras that were affordable. Please keep bashing comments to yourself.
                          you can still run FI on the car my motor guy said .030 would have been fine....
                            Pacesetter Headers
                            No Cat
                            Hooker 3" Catback
                            Aluminum Driveshaft
                            no problem man...its got a warranty so if i blow it up i'll be sure to let ya know lol [img]smile.gif[/img]
                              I was kinda thinking the same thing, all that and no cam? But i know how it is to be tight on funds and reliability is sometimes a bigger issue then speed. Anyways good luck with your new engine. Let us know how she runs for ya. Got any pics?
