Does anyone know someone who has a lot of experience in programming PCMs. I want the PowerPak but I also want to bore my block and raise the compression ratio. I will definately need an entirely new PCM program. I don't want to send my PCM to just anyone.
PCM programming
DO a Search ON PCM programming and do a search on boring the block. You're not going to gain much if anything from boring the block. Besides i only think you can bore it .010 or something like that.2001 Black S10 Xtreme 4.3L A4<br />*RedLineVSix*<br />\"Throwin sparks, draggin frame\"
<blockquote>quote:</font><hr>Originally posted by Jason:
DO a Search ON PCM programming and do a search on boring the block. You're not going to gain much if anything from boring the block. Besides i only think you can bore it .010 or something like that.<hr></blockquote>
:rolleyes: :rolleyes: :rolleyes:
Well, the stock block can be bored only slightly.. .020 safely, maybe .030 max, from what I have read.
Either way you only pick up a few cubes and I don't believe its worth the $$$ for 1-2 rwtq.Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
