I keep hearing about getting l67 internals for our cars to withstand higher boost level, but I don't hear about how the crankshaft will hold up. How much hp/tq can you put on it before you break it? will I need to get the whole rotating assembly balanced when I put l67 rods/pistons in later on? since forged rods are lighter than cast rods, I figure that I will have to have it balanced so I don't lose power due to unequal weight. If I do need to have it balanced, should I just get it knife-edged or just reduce the outer diameter of the counterweight itself, or should I just get a custom forged crank and leave it at that? Thanks for your imput.
how strong is the l36 crankshaft?
2001 Arctic White Firebird<br />T-Tops, 3.42 rear gear stock<br />Mods:K&N Air Filter,Whisper Air Induction Lid, maf screen removed, raised air box, Kumho Ecsta 712 255-50-ZR16 tires, BMR stb<br />Mods not installed yet: FTRA, SLP Lsd/Differential cover<br />Near Future Mods: HPP3, GMMG 3\" Exhaust , 1LE Swaybars, Transgo Shift Kit, MSD-DIS-4 w/ Accel Coil-Packs, Turquoise Blue Neon Underbody Kit, BMR Adj. LCA\'s, G2 Sfc\'s & V-braces, Pacesetter headersTags: None
Its a good idea, whatever you go with, to have your assembly hardened and blueprinted/balanced before installing it yes.
I would imagine that the L36 crank can handle nearly 500ftlbs without breaking, its a rare thing to break the crank but it has happened. If you want to make sure it won't break, buy a custom steel one, you should have no issues with that.2002 5-spd NBM Camaro
Details: www.1lev6.com
<blockquote>quote:</font><hr>Originally posted by Jhonathan:
dont say it cant happen my roomate broke his in his 96 3.8 camaro and he doesnt even have any power adders!<hr></blockquote>
I don't know what he did to break that but I've seen cams bending and push rods bending, and rods bending and the crank is ok. My teacher showed us a bent up cams that used a 300 shot of NOS. I don't know how much poundage a crank can take but that is something I would think of last when it comes to breaking.
thank god. ok, so all i'd have to do when I get l67 internals is get the thing ballanced and/or knife edged, right?2001 Arctic White Firebird<br />T-Tops, 3.42 rear gear stock<br />Mods:K&N Air Filter,Whisper Air Induction Lid, maf screen removed, raised air box, Kumho Ecsta 712 255-50-ZR16 tires, BMR stb<br />Mods not installed yet: FTRA, SLP Lsd/Differential cover<br />Near Future Mods: HPP3, GMMG 3\" Exhaust , 1LE Swaybars, Transgo Shift Kit, MSD-DIS-4 w/ Accel Coil-Packs, Turquoise Blue Neon Underbody Kit, BMR Adj. LCA\'s, G2 Sfc\'s & V-braces, Pacesetter headers
