my twin turbo 3.4 - FirebirdV6.com/CamaroV6.com Message Board
my twin turbo 3.4
  • my twin turbo 3.4
    In the future I plan on building a twin turbo& intercooled 3.4L camaro.Untill then I need help collecting info.
    I'm going to use either 2 t03s or t04s,canted valve aluminum heads from gmpp,and the intake manifold from gmpp.I need help with:
    finding good pistons&rods&crank
    finding a solid roller cam
    how to disable the top speed governer&rev limiter
    if i can replace the t-5 trany with a t-56
    any feedback is appreciated
    apperance mods I plan to do ;
    stella tech ground trim,SS rear spoiler,ram air hood from jegs,and I'll paint it black w/ grabber green stripes :cool:
    Wolf<br /><a href=\"http://www.cardomain.com/memberpage/249111/7\" target=\"_blank\">95 black t-top camaro</a>,3.4 5 speed,ud pullies,plugs/wires,de-shaft tb & gutted airbox, homemaid short throw shifter
    humm, the heads wont work.
    so the intake wont either
    pistons-custom
    rods-modified small block rods
    crank-custom
    roller cam wont work due to bearing oiling issues on our blocks.
    top speed gov- custom computer reprogram
    t5 to t56, would be interesting, Im sure it could be done.
    good luck, I want to see it done.
      thanks for the info tiago,damn.. the gmpp heads wont work?? Ok 2 Q's 1. why? & 2.what heads & intake do you recomend ,i've seen that fancy LT1 throttle body intake but couldent find mutch info on it.
      [img]smile.gif[/img]
        heads/cam/intake the only thing you can do now, is talk to supersix. nutek quit making the set I have.
          thanx again i'm here to learn as mutch as i can.
          I'm just waiting 4 someone to tell me to scrap the turbo idea and get an 8 (if i had a doller for every time someone has said that.....)
          i did some digging and seen a quote "tiago is the gawd of 3.4's" ;)
            LOL :D
              *Brian reaches into his wallet for the $1*
              Jeez, just get a V8
              -Brian
              Maroon 1995 Camaro<br />No mods yet...<br />Lucky to have found this site!
                **** you :D
                  [img]graemlins/rofl.gif[/img] [img]graemlins/rofl.gif[/img] [img]graemlins/rofl.gif[/img] [img]graemlins/rofl.gif[/img]
                  1998 Jet Black Trans-am M6 T-tops<br />\"Ask, and it shall be given you; seek, and ye shall find: knock and it shall be opened unto you:-Matthew 7:7<br />Old car<br /><a href=\"http://matthew27529.tripod.com/getsome\" target=\"_blank\">http://matthew27529.tripod.com/getsome</a><br />NEW CAR<br /><a href=\"http://garnerebel.tripod.com/\" target=\"_blank\">http://garnerebel.tripod.com/</a>
                    [img]graemlins/rofl.gif[/img] way to go tiago [img]graemlins/thumbsup.gif[/img]
                      I had to... it was just too good.
                      -Brian
                      P.S. good luck on that twin turbo project, I hope you do it!
                      [ April 17, 2002: Message edited by: Brian Dieckman ]</p>
                        I will but it mighnt take 20-30 years :D
                        .........i dont even have my camaro yet [img]graemlins/crybaby.gif[/img]
                        my current car is a '75 nova ln with a 262 v8,when its done(99.5% complet now) im gonna start svin 4 it.... [img]graemlins/evilgrin.gif[/img]
                          any ideas where you are going ot place the turbos? how you are going to do the exhasut manbifolds?
                          I have some ideas, cuz I too think a twin turbo would be pretty ideal, but doubt I will ever do it.
                            OK here gose...
                            the turbos will probably be wedged between the radiator and the engine.The exhasut manifolds...
                            well fabrication(no, not masturbation) is a mans best friend.
                            two air to air intercoolers,will probly be mounted slightly under&behind the radiator
                            if you have any ideas I want to hear them, I got a long time to study to make this work
