So I finally got an MAFT and decided to Port the TB. I have read all the posts regarding this and havn't had any luck yet.
I only took out the bottom half of the post, and installed a TB spacer I had it off. It is making a lot more power but I have some issues.
I was initally very pleased (knowing the initial results were expected) with the autotap readings around .95 on S1B1 .97 and S1B2 at idle; .94 on both while driving and about .85 at WOT. It idled ok, with a slight lope until it warmed up and then progressivly dissappeared.
My readings have gotten progressivly worse after leaning out the base 5% and richening WOT by 2%. The engine started loping very bad to the point of almost stalling. I went back to the computer controlling everything with no luck. My o2 readings are off the scale now and are hovering around 0 for normal driving and idle but are still giving me readings at WOT.
I also threw multiple trouble codes.
Misfire
Lean bank 1
Lean bank 2
Did I fry my O2 sensors with the rich condition?
If so, where do I find wide range O2 sensors?
Should I go to the 99+ sensor and romove the top of the post?
I reset the PCM last night and cleared all the codes but it didn't help.
What should I try next.
Any help is appreciated, I'm scared to drive my car like this and I was hoping to take it to the track tommorow morning with the great weather we are having here in the great state of MD.
[ November 29, 2002: Message edited by: jonny985 ]</p>
Misfire
Lean bank 1
Lean bank 2
