I have heard a few differt things, I have a VS comp cam and I am going to have it put in, what are all the gaskets and things I will need? Thanks Guys and I did search but didnt come up with much.
Need help with cam parts
Ok, this is just off the top of my head, but.
Upper and Lower Intake Manifolds
Throttle Body Gasket
Front Engine Cover Gasket
Thermostat O Ring
Valve Cover Gasket
Cam Bolt
Crank Bolt
Rocker Arm Bolts (12)
That's a pretty good start right there. I don't really recall using anything else as far as gaskets.<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a><br /><a href=\"http://www.chitownracing.com\" target=\"_blank\">www.chitownracing.com</a>
Not off hand. Call your local dealer, they can give them to you, or look them up on gmpartsdirect.com I know most of them come in a kit from GM<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a><br /><a href=\"http://www.chitownracing.com\" target=\"_blank\">www.chitownracing.com</a>
You would be a cheap bastard, and a dumba55. The bolts are less than $20. Why would you put in a $300 part and skimp on the most important parts. The bolts are torque to yield. Which means they are streched and distorted when torqued to full load. When reused, you run the risk of breaking the head off the stud. Would you want that to happen while cranking at 6000 rpm? Not likely. It's really cheap insurance against sending your harmonic balancer through your hood.<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a><br /><a href=\"http://www.chitownracing.com\" target=\"_blank\">www.chitownracing.com</a>
If you have a car with over 50K miles on it, I'd highly recommend replacing at least your timing chain also, if not the gears and tensioner. It's just good practice to do this, just like the head studs. It will gaurantee yur car a longer life without a broken chain and downtime.<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a> THE SOURCE!
Yes, you can go to your GM dealer's service department and they should have them in stock even. Or check out www.gmpartsdirect.com as they have a bunch available also.<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a> THE SOURCE!
valve cover gaskets (2)
lower intake to head gaskets (2)
valley end gaskets (2)
plenum gasket (1)
oring (small) at plenum (1)
oring (big) at plenum (1)
cam sproket bolt (1)
crank bolt (1)
rocker arm bolts (12)
cam lube (1 bottle)
engine assembly lube (1 bottle)
if it's a high mileage engine
valve seals-blue (6)
valve seals-green (6)
valve springs (12)
valve spring retainers (12)
keepers (24)
i bought the l36 cam install kit from ZZP, then bought whatever else i needed besides that. saved me about $80 CAD, and i'm crossin' my fingers that it'll all work for my RWD l36. find out tomorrow tho :D
--matt
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...3 weeks ago
