Ok, I'm halfway through my heads and cam install and I can't get the balancer back on the crank. We've tried everything from tapping it on with a wooden block, to tightening it with the old bolt to heating the sliding surface of the puller with a torch. The dam thing won't go the last 1/2" to seat against the timing sprocket.
Is there a trick to this. I just line it up until it hits the key, then push it on by hand and then try to get it seated.
Thanks
1996 Silver Camaro, Y87, M5, cammed..<br />N/A Best Time: 14.012 @ 98.59<br />195 rwhp / 233 ft-lbs b/f heads/cam<br />Check out my site <a href=\"http://silver3800.cz28.com/\" target=\"_blank\">http://silver3800.cz28.com/</a>
The only thing that I can think of as well is that that there must be something obstructing it. I am trying not to have to remove the timing cover again and get new gaskets.
-Jon
are you sure that crank sprocket is in the keyway, and not sticking out? did you have any probs installing the timing chain? is the front cover installed right?--> if the front cover is mounted flush then your oil pump is installed correctly is what i'm getting at.
--matt
[ October 27, 2003: Message edited by: awesomeame ]</p>
The crank sprocket went on fine and on the key (the only way it would go on I think). I installed the front cover correctly and torqued all the bolts to right amount. I may have to pull it off and check it out if I can't get this dam thing on.
i put my pulley back on yesturday, and i had the same prob as you did...lined up the keyway & it wouldn't go on...turns out i had the pulley cocked a bit, so it wasn't going on perfectly straight...i had to pull it off with a harmonic balancer puller & then i put it on straight, no probs.
