3.8 rebuild question - FirebirdV6.com/CamaroV6.com Message Board
  • 3.8 rebuild question
    I am thinking of pulling my engine to rebuild it soon so I want to add it up to see what it will cost. I am wondering if someone can give me part# for what I will need. I want to go with the new series III connecting rods. what will i need to go with these? (what bearings)I am also wanting to up the compression ratio, what pistons are best? what piston rings are best? also what do I need to have the machine shop do to the block other than boring it? I have heard something of removing a balance shaft or something? where can I get my PCM tuned for a new cam and any other changes? I guess if anyone has a list of the parts nd part # that would rally help me out. where is the best place to buy the parts? any help would be great. thanks.
    also how much can these engines be bored?
    [ October 27, 2003: Message edited by: white96six ]</p>
    white 1996 camaro 3800: flowmaster American thunder cat back. hypertech 160* stat, and manual fan switch
    I have a set of SSM heads that would go good on a rebuilt engine. Let me know if you want them.
      I am very interested. send me an email at white96sixv6@wmconnect.com ASAP. [img]graemlins/burnout.gif[/img]
        A good thing to do(in my opinion) while your block is at the machine shop is have your block, as well as rods shot-peened. Shot-peening aligns the molecules in your cast iron black and makes your block a bit stronger and less prone to damage. And usually a block is only about 50 or so bucks to have this done, in my opinion ITS WORTH IT.
