Just wondering what kinda cam i should get, i want one that pulls hard in the mid range and a little up top, and good around town.
Cam help
Check out ZZperformance.com. If you're gonna go N/A check out the GT cam(210/210 .507 112LS 108IC). I would definitely get new retainers and springs with this cam though. If you're gonna go with boost, run the VS cam. I heard only good things about this cam if run with boost.
I like the GT2 cam on the ZZP site it's 216/216 111lsa with .507/.507 lift. It's a little more punchy than the GT and has a better lope. You have to get a verter with some PCM tuning though.2000 Firebird. Whisper Lid, True duals, TSP mail order tune, Built Tranny , TCI 2800 stall verter, B&M tranny cooler, Eaton LSD, 3.42 gears. Current best ET. 15.232 89.09 MPH 2.175 60ft on stock 3.42\'s and open diff.<a href=\"http://www.geocities.c
I looked at the new GT2 cam also. The problem is that you have to get your computer reprogrammed. Most people have complained that ZZperformance doesn't actually do this and no one else is reprogramming the 3800 II. If you have someone lined up that KNOWS how to do this, than I'd go with this cam. If you don't, just get the GT cam and be content with having 5 less PEAK HP. It can be a big headache and PITA if you go the way of the GT2.
<blockquote>quote:</font><hr>Originally posted by dfedzina:
I looked at the new GT2 cam also. The problem is that you have to get your computer reprogrammed. Most people have complained that ZZperformance doesn't actually do this and no one else is reprogramming the 3800 II. If you have someone lined up that KNOWS how to do this, than I'd go with this cam. If you don't, just get the GT cam and be content with having 5 less PEAK HP. It can be a big headache and PITA if you go the way of the GT2.<hr></blockquote>
Digital Horsepower does it for $3002000 Firebird. Whisper Lid, True duals, TSP mail order tune, Built Tranny , TCI 2800 stall verter, B&M tranny cooler, Eaton LSD, 3.42 gears. Current best ET. 15.232 89.09 MPH 2.175 60ft on stock 3.42\'s and open diff.<a href=\"http://www.geocities.c
