Keith, just a question, .... - FirebirdV6.com/CamaroV6.com Message Board
  • Keith, just a question, ....
    I was reviewing your site, why didn't you go with the full engine rebuild? It did not see any information on a new set of pistons. rings, etc, since the engine was under construction anyways..
    Just looking for info and is the firebird your daily driver?
    dave - hope to see you around Chicago
    If anyone knows the Midwest F Body site I would appreciate the URL and ability to show up to one of the locations....
    [ April 21, 2002: Message edited by: Silent Majority ]</p>
    www.mfba.org Just don't tell them Dom told you. This way the board admin. won't hate you from the start. ;)
      Thanks Dom....
      Have a good one...
      dave
        Its not worth it on the V6 imho. I could spend a couple gran on internals, R&D and whatnot.... but why? its just a V6.
        I'll just blow it up with nitrous and spend $500 on a replacement motor.
          Keith, thanks for the feedback....
          dave
            Hmmm... I would buy a 2nd block and build a supercharged or turbo setup. All you would really need would be a set of forged pistons, might be able to reuse the stock rods. I think a stock 3.8 can probably handle 8-9 lbs of boost if it was intercooled.
            98 Pontiac Formula<br />10.3@136 | 1.58 | 3450 Raceweight
              There is a kit in the works that is aimed at 10lbs of boost. We shall soon find out.
                Since the topic already had a good name i thought i would reuse it Magnus does you Jet Scu thing work good. Does it remove the speed limiter and will it work on a 2000 camaro
                <b><a href=\"http://www.sick-sixx.com\" target=\"_blank\">SICK-SIXX MEMBER</a></b><br />NA 14.345 with a 1.863 60 foot<br />Nitrous 13.03@99.5 with a 1.63 60 foot<br /><br />2000 Camaro 3.8L A4: USE TO HAVE Comp Cam 210/220 .535/.547 113lsa 111 I/C, Port and Polished Heads, NX Wet Kit 100 Shot, CPRA made by CP, RK Sport Headers
                  keith since its just a v6 why did you spend over 1700.00 on heads and cam? why didnt you just buy the v8?
                    <blockquote>quote:</font><hr>Originally posted by slacker69:
                    Since the topic already had a good name i thought i would reuse it Magnus does you Jet Scu thing work good. Does it remove the speed limiter and will it work on a 2000 camaro<hr></blockquote>
                    No it doesn't work good at all. Shift points willl still be off. It only fixes the speedo.
                      <blockquote>quote:</font><hr>Originally posted by bluecmaro96:
                      keith since its just a v6 why did you spend over 1700.00 on heads and cam? why didnt you just buy the v8?<hr></blockquote>
                      Insurance payments.
                      It takes money away from other stuff.
                      [ April 27, 2002: Message edited by: Dom ]</p>
                        But will it take off the top speed limiter
                          slacker,
                          The SCU *can* take off the speed limiter, but all it does is stop the speedometer at 100. That means that if you set the SCU to disable the speed limiter, at WOT the car will not shift into 4th gear. Our transmission shifts into 4th at ~104mph, if the car only reads 100mph then it wont shift. The SCU2000 has a little jumper that you set to enable/disable the speed limiter. I keep mine enabled so it will shift into fourth at WOT. I have never really needed to go that fast at WOT anyway, so its not that big of a deal.
                          ~Brian
                          NEW 2002 Onyx Black SS Camaro<br />M6, leather, T-tops, Hurst shifter<p>sold: 1999 Pewter V6 A4 Camaro
                            Woah!! I didn't spend 1700 on heads/cam!!! :eek: I spend under 1000.
                            The jet SCU works decently. It does what it claims to do.. and yes I use it to have no top speed limiter.
                            The problem with the Jet scu is that it only corrects the speedo, not the shift points.. so you have to manipulate your speedo with the Jet SCU to get shift points that you like. (Shift points are based off of MPH).
