How would I be able to raise the redline. Besides moving the rev limiter what else needs to be done to do this safely?
Raising the redline
stiffer/lighter valvetrain components help so you don't get any valve float such as titanium valve springs/retainers, hardended pushrods, aluminum roller rockers. make sure your injectors can accomodate the higher need for fuel. maybe getting your rotataing assembly(carnk, rods, pistons, flywheel) balanced to the sub-gram level, but that's kinda extreme. forged internals to handle the additional stress. upgrading the cooling system later down the line will help if you are gonna do more mods to your car since more combustion cycles will occur with a higher redline. can't think of much else.2001 Arctic White Firebird<br />T-Tops, 3.42 rear gear stock<br />Mods:K&N Air Filter,Whisper Air Induction Lid, maf screen removed, raised air box, Kumho Ecsta 712 255-50-ZR16 tires, BMR stb<br />Mods not installed yet: FTRA, SLP Lsd/Differential cover<br />Near Future Mods: HPP3, GMMG 3\" Exhaust , 1LE Swaybars, Transgo Shift Kit, MSD-DIS-4 w/ Accel Coil-Packs, Turquoise Blue Neon Underbody Kit, BMR Adj. LCA\'s, G2 Sfc\'s & V-braces, Pacesetter headers
Patrick tends to think on the extreme of everything.
Maybe if you're thinking of ballzout rev limiter raising, but if you're talking another 500 - then I can see new rockers and springs.2002 Camaro SS 6 Spd<br />Sebring Silver Metallic<br />Still breaking it in<p>Traded in - 2002 V6 5 Spd Camaro.<p>\"I\'ll never trust squirrels again.\"
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...4 days ago
