I think i am going with the new cam from AMM perf - FirebirdV6.com/CamaroV6.com Message Board
  • I think i am going with the new cam from AMM perf
    It is a 210/220 .533/.533 115LSA 111 I/C
    This is gonna be for my Supercharger/Nitrous application
    What do yall think
    <b><a href=\"http://www.sick-sixx.com\" target=\"_blank\">SICK-SIXX MEMBER</a></b><br />NA 14.345 with a 1.863 60 foot<br />Nitrous 13.03@99.5 with a 1.63 60 foot<br /><br />2000 Camaro 3.8L A4: USE TO HAVE Comp Cam 210/220 .535/.547 113lsa 111 I/C, Port and Polished Heads, NX Wet Kit 100 Shot, CPRA made by CP, RK Sport Headers
    What brand cam is that?
      comp cam
        It would be nice but are you sure compcams can put that grind on a 3.8 cam? That might be 3.4 cam specs.
          yeah im sure check it out
          http://www.ammperformance.com/V6Main.htm
          goto internal engine and scroll down till u see it it is the last one on the 3.8L cam list he told me he was gonna get a cam list for us.
            Yup, I called this morning for specs on the 3.8L V6 cams...These cams will take approx. 4 weeks to make. Otherwise, all information is updated and correct. Lemme know if any of you have any questions.
              you gonna start selling some valve springs for the 3.8L shouldnt be hard they are the same as the LS1 cause i plan on buying very very very soon.
                <blockquote>quote:</font><hr>Originally posted by slacker69:
                you gonna start selling some valve springs for the 3.8L shouldnt be hard they are the same as the LS1 cause i plan on buying very very very soon.<hr></blockquote>
                Are they definitely the same ones as the LS1?
                If so, I offer about 5 different sets. Lemme know ASAP and I will throw them on the board.
                  Yes magnus uses ls1 ones pgif uses ls1 ones they are all the same tom @ supersixx motorsprts uses them as well
                    I didnt know those specs were available. That is alot of lift though. You better get some nice springs. Even with 115LSa on a cam with that much duration there is still alot of valve overlap. IT should be nice for your 'charger setup though. I like it.
                      I will throw the 3.8L Valve springs on right now if that's the case.
                        What about retainers and valve locks?
                          <blockquote>quote:</font><hr>Originally posted by viper98885:
                          I will throw the 3.8L Valve springs on right now if that's the case.<hr></blockquote>
                          I am not certain that all LS1 valvesprings will work but I can tell you for sure these ones do because these are what I am running. I do believe I am running stock locks, retainers with these springs.
                          Compcam part# 26915
                          http://www.compcams.com/information/...ess/ls1_bw.PDF
                            i think the 916,942 and 915 work for us also i know the ls1 titanum retainer works if there are more than great. Also what about pushrods.
                              What info can you all give me about the 3.8L V6 valves other than what's in the Engine Tech section? I.e. How many grooves for the valve locks, what's the valve stem diameter...I am trying to see if the Manley valves for the LS1 will work in your 3.8L V6.
