Need some input - FirebirdV6.com/CamaroV6.com Message Board
Need some input
  • Need some input
    ok, my 95 3.8L camaro doesn't have much left in her........but i DO NOT wanna get rid of her. Some of my friends (HUGE car junkies) have been hassling me to let them swap a V8 into it.....well i think the time has come. We are going to do all the work ourselves, but i need some input from you guys on which to go with LS1 or LT1. i know the LT1 has 285 hp, and the LS1 has 300 hp........but what else am i looking at? and i know that the LT1 can prolly fit easier, but i see magnus has done the LS1 swap into his 97....so its NOT impossible :D
    anyways, if you guys can give me some pros and cons it would be GREATLY appreciated!
    oh, i got like 4grand to use......and my friends say go with the LS1...but i dunno if they are aware of any obstacles that may arise.
    thanks guys!
    Johnny M. <br />Black 95 3.8l CAMARO A4<br />Enough mods.....for now, hehehe!<br /><a href=\"http://www.cardomain.com/id/jpmabasa\" target=\"_blank\">My RIDE</a><br />\"I promise, it IS a v6!\"
    The LT-1 is cheaper has a stronger block but not as much horsepower stock. The LS-1 has an aluminum block and more horsepower stock. Both have great aftermarkets. If you are going forced induction anytime in the future the LT-1 would last longer due to the stronger cast iron block. They are both great engines. It's a matter of preference and what you are planning for the future.
    2000 Firebird. Whisper Lid, True duals, TSP mail order tune, Built Tranny , TCI 2800 stall verter, B&M tranny cooler, Eaton LSD, 3.42 gears. Current best ET. 15.232 89.09 MPH 2.175 60ft on stock 3.42\'s and open diff.<a href=\"http://www.geocities.c
      thanks for the reply, any other comments?
      i did not know that the LT1 had a stronger block......are the aftermarrket prices cheaper too?
      thanks,
        with 4 grand you are really close to a LT1 crate engine.... brand new, no miles. 2500 more and you can convert it to LT4 heads, hot cam and intake which will jump you to around 425 horsies at the crank. check out www.paceparts.com and search lt4 kit.
        im looking into this but its gonna be at least two years down the road after I pay off my car because when i do it, its gonna be a HUGE investment.
        Most LT1 aftermaket parts are slightly cheaper than LS1, but not so that if you can afford one, you cant afford the other. Supercharges are a few hundred cheaper, but again when your talking over 3 grand, a few hundred is only a percentage.
        [ November 06, 2003: Message edited by: ellik ]</p>
        \'01 Mineral Grey SVT Cobra<br />-former F-body owner
          THANKS! i didn't know crate engines where anywhere close to that price range...where can i see this kind of stuff?
          thanks...anyone else?
            check out jegs, summit, jcwhittney...
            heres a couple other things i found....
            for the price of an LS1 crate engine.....
            [URL=http://chevyhiperformance.com/techarticles/84498/index6.html]
            this ones for a 93-94. $4500
            [URL=http://www.sdpc2000.com/cart.asp?action=prod_detail&catid=128&pid=108]
            i cant find the link to the site i was on yesterday. its still around the 4500 for the 95-97 lt1. ill keep looking for it.
            just remember after the engine you will still have to find a tranny to bolt it to.
              You could feasably get a used LT-1 and tranny from a junkyard have it rebuilt and in your car for close to $4K. About 7K if you do the LT-4 upgrade
                ok, so used it is...i forgot about needing a tranny too. and we are doing the work ourselves...so no labor costs needed :D
                any ideas where to look for some used packages?
                  www.tacreationsusa.com
                  ebay
                  local junkyards
                    Hello turbo. Boo all you noisy V8's.
