What are the cam specs on a stoke 3.8 cam? - FirebirdV6.com/CamaroV6.com Message Board
  • What are the cam specs on a stoke 3.8 cam?
    Just curious to see how much we would gain on going with a mild high pro cam fro N/A purposes.
    2004 Dodge Dakota 3.7 litres of raw power!!<br />Nothing but a 6!<br />Do you know for sure? John 3:18
    mild hi pro?
    stoke?
    What kind of terminology is this? What are you asking?
    2002 5-spd NBM Camaro
    Details: www.1lev6.com
      its all in the database, john.
      dom, like you can't interpret?
      \'96 <b>Quasar Blue</b> Firebird A4<br /><a href=\"http://jamiethekiller@comcast.net\" target=\"_blank\"><i>jamiethekiller@comcast.net</i></a><br /><a href=\"http://www.woodlandrock.com\" target=\"_blank\">my band: woodland</a>
        You can't stroke the 3.8, just get a good L36 cam from a preformance site. Grand prix sites seem to know their stuff, since they have the fastests L36's.....www.intense-racing.com....www.zzppreformance.com
        1997 Red GTP Coupe<br />Borla,3\" DP,!ubend,Thrasher CAI,Magnuson(3.4\"),1.9 roller rockers,Tran. Cooler,GPS PCM,Boost+Trans. Temp gauges(in Lotek),comp harness,Blazertech 3200\'s,BBS 18\'s+Pilots,RAT rear sway bar,Powerslots+Pf Pads(all corners),KYB\'s,STB\'s,Poly bushings(mid+end),Optima Battery(yellow), Kenwood Deck+Boston Interior Speakers(Pro)+RF Sub(550 watts), GTS covers,rear red reflective Pontiac sticker(My fav.)
          You are very wrong about that, with the right amount of money you can stroke the 3.8
          Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
            http://tech.firebirdv6.com/cam.html
              <blockquote>quote:</font><hr>Originally posted by MoreThanAV6:
              You can't stroke the 3.8, just get a good L36 cam from a preformance site. Grand prix sites seem to know their stuff, since they have the fastests L36's.....www.intense-racing.com....www.zzppreformance.com<hr></blockquote>
              Its pretty pointless to stroke the 3.8, and currently since nobody has done it - its damn near impossible. I agree with you on this about the grand prix sites, they seem to carry a lot more hard core stuff for us than most others.
                Ok, I give up, I cannot spell. :mad: I meant stock not stoke, sorry for the confusion. What are the stock cam specs on a 3.8 and what kind of cam should be used to see if any at all increase in N/A form with changeing springs, retainers, or rockers. Something also that would be computer friendly so nothing too radical.
                  why would you want to put a cam in and not be radical??????
                    <blockquote>quote:</font><hr>Originally posted by toast:
                    Ok, I give up, I cannot spell. :mad: I meant stock not stoke, sorry for the confusion. What are the stock cam specs on a 3.8 and what kind of cam should be used to see if any at all increase in N/A form with changeing springs, retainers, or rockers. Something also that would be computer friendly so nothing too radical.<hr></blockquote>
                    The Comp 206/212 113LS grind is a great upgrade on stock internals and such. Changing the springs is recommended. Min saw 212 rwhp just by swapping cams on his 00 V6 bird with this cam [img]smile.gif[/img]
                    Stock specs are 182/190 0.413/0.408 115LS
                      Ok so will that cam Dom give me a nice lopey idle and I trust it gets rid of that dreaded raspyness up high. I don't want anything too too radical that my car wont idle for anything. By the way, in refrence to cam specs, what gives the idle and the rest of the rpm range that lopey exhaust note?
                        <blockquote>quote:</font><hr>Originally posted by Dominic:
                        <hr></blockquote>
                        That's incorrect. He also had his heads and intakes ported/polished. Don't even bother telling me I'm wrong, because I talk to him daily, and we've discussed it MANY times.
                        T
