is it better to run lean or rich... - FirebirdV6.com/CamaroV6.com Message Board
  • is it better to run lean or rich...
    on an N/A car with just full exhaust, and intake
    96 Camaro M5. Dark metallic gree (?dont know the offical color name)<br />Home made Intake :: Headers, 3inch headers back to Flowmaster muffler :: spec stage 3 clutch Now installed, waiting for 3.42\'s and LSD next month<br /><a href=\"http://photobucket.com/albums/y192/RiceEatingCamaro/?action=view&current=newcar.jpg\" target=\"_blank\">My Car</a> <br /><br />Totalled Car.<br /><a href=\"http://bellsouthpwp.net/s/k/sk8er305/\" target=\"_blank\">96 CamaroRS</a>
    What are you trying to accomplish? Power? MPG? Knock supression?
    [ April 23, 2002: Message edited by: Dominic ]</p>
    2002 5-spd NBM Camaro
    Details: www.1lev6.com
      always better rich than lean
        I would think you want neither more than the other, but a I guess rich(more air) is better...
        Bolt-ons and lots of em\' <p>best ET 12.9@104mph
          If you run lean you have a greater chance of damaging your engine.
          1995 Camaro 3.4 v6. Dead<br />1995 Trans Am FIPK.
            thats all i needed to know... i was just curious
              Its MUCH safer to run rich.
              It's very dangerous to run lean on a power adder motor.
              NA it can help power to run lean.
                I thought rich was more fuel?
                1997 Dodge Viper GTS
                  Rich = more fuel
                  lean = less fuel
                    How do you tell if you're running rich or lean??? I guess some people can tell by the smell of the exhaust? I can't!!!
                    <a href=\"http://www.cardomain.com/ride/2093533\" target=\"_blank\">CarDomain Page</a>
                      wide band o2 sensor
                      you could also use stock o2 sensors with autotap, but your readings wont be THAT accurate.. wide band is the best way.
                        what is wideband? A certain type of O2 sensor?
                          ya what is wideband magnus
                            Wideband is an o2 sensor that reports a fairly linear voltage change, over a wider range of a/f ratios. The stock o2 (narrowband?) will report tiny little variations in a/f on either side of 14:7, but when you move very far from center, the voltage changes a lot, and you can't distinguish the ratio anymore.
                            Stock sensor would be kind of like a speedometer that told you within a 1/10 of a mph, how fast you are going, but only while you are going 55-65. And it would just report a steady 40mph if you were driving anywhere from 0-50. Or a steady 80mph if you were driving between 70-100.
                            Wideband would accurately report mph, to within 1 or 2 mph, from 10-100mph.
