3.4L V6 Cams - FirebirdV6.com/CamaroV6.com Message Board
3.4L V6 Cams
  • 3.4L V6 Cams
    Okay so we can say ive done some research and this is the list ive came up with. I dont know if these work with the computer, i havent called yet.
    Heres the list.
    Lunati
    Phone # 6628930698
    http://www.lunaticams.com/Camshafts/Chevy1.html
    Duration @ .050: 210/210
    Adertised: 260/260
    Valve Lift: 441/441
    Lobe Seperation: 110
    Price Cam Only: 105
    Good idle. Good performance cam for street use. Good mid range and top end. Power range 1000-5500.
    Crower
    Phone #6194221191
    www.crower.com
    #03015
    Duration @ .050: 204/214
    Advertised: 283/286
    Valve Lift: 422/444
    Lobe Seperation: 112
    Price: 85
    RPM Power Range: 1800 to 4500 / Redline: 5750 plus. Strong upper bottom and top end power
    #03043
    Duration @ .050:212/218
    Advertised: 278/284
    Valve Lift: 435/449
    Lobe Seperation: 108
    Price: 135
    Street/strip cam. Super top end torque. RPM Power Range: 2000 to 5000 / Redline: 6000 plus.
    CompuCam
    Phone #3862586174
    http://www.cranecams.com/master/apps/chevy1.htm#2. CompuCam
    Duration: 204/214
    Advertised: 264/274
    Lift: 423/423
    Lobe Sep: 109
    Price(w/lifters): 160
    Mid and upper range torque and HP improver for cars, especially Camaros, S-10 pick-up's, Blazers, Jimmy's, etc., and all perf. applications. Basic RPM 1500-4500
    For Sale<p>Mods so Far:<br />Tb Coolant Bypass, NGK Vpower Plugs, Accel 8mm Wires, Gutted Cat, TransAm Muffler, K&N FIPK, Crower Baja Cam, Comp Cams Magnum Rocker Arms 1.52 Ratio, Ported Throttlebody, Ported Intake Manifold, 3.73s and Auburn LSD, Yellow Underbody Neons, Milled Heads, Pacesetter Headers, TransGo Shift Kit, 1 Piece DS, Accel Coils, Rk Sport Air Temperature Module<p>Soon Mods:<br />Nos 5175, Rims, Stage 2 Jet Chip, Jet Underdrive Pullys, Strut Tower Brace, Subframe Connectors, Speed Calibrator, Lowering Springs
    this may be an advanced tech question, but:
    What is the difference, if any, between the stock 3.4 cams in your engines, & the one offered in the gmpp catalog for the 3.4 crate motor?
    2013 Ram 1500 Big Horn
    94 comero 3.4
      Here's all the research you need:
      http://www.s-series.org/htm/performance/60degree.php
      94 Quasar Blue Z28<br /><a href=\"http://www.9t4z28.com\" target=\"_blank\">http://www.9t4z28.com</a><br /><a href=\"http://www.9t4z28.com/Dyno1.htm\" target=\"_blank\">http://www.9t4z28.com/Dyno1.htm</a>
        http://www.s-series.org/htm/tech/60D...DegreeCams.htm
        http://www.engine-parts.com/GMV6/28camspecs.html
