1.6 roller rockers on 3.4 - FirebirdV6.com/CamaroV6.com Message Board
  • 1.6 roller rockers on 3.4
    Does anyone run the comp camps 1.6 ratio roller rockers on their 3.4? I'm very intrested in ordering a set to see what happens. They are fairly cheap compared to some bolt-ons, and you WILL get an actuall HP increase compared to some that can't say the same...
    Ric Johnson<br />----------------<br />1995 Pro AM III #12<br />3.4 A4<br />KN FIPK intake with ram air mod<br />Flowmaster exhaust<br />RKSport IAT sensor <br />ASP Underdrive pullys<br />TB Bypass<br />PF52 larger oil filter<br />3.42 non posi rear end<br />DeCarbon Trans Am shocks<br />Eibach pro series springs<br />B&M Shift Plus+ (best $40 ive ever spent)<br />Custom made billet alum front end inserts<br />Interior trim painted to match the car<br />Awia CD player with factory bose sound system<br />Viper alarm system<br /><a href=\"http://www.proam.webhop.org/\" target=\"_blank\">http://www.proam.webhop.org/</a>
    Im in the same boat as you man, I would like to know as well, cuz i need some!
    Black 1995 3.4L V6 \"<b>THE BLACKBIRD</b>\"<br /><b>Performance Mods </b> K&N Fipk, Hypertech Underdrive pullies, Accell Coilpacks, and wires, rapidfire plugs,180 degree thermo, 1LE Tranny Mount, Z28 Catback W/crome tips B&M Ripper shifter<p><b>Appearance mods</b> 2 1/2% Limo tint all around, Blacked out taillights, turn signals, and side markers, red PONTIAC rear Inlay, 98+ style centerplate bird and graphic<p><b>Stereo System</b>Panasonic Cqdf 800u head unit, 2 MTX thunder 280 amps bridged, 2 Cerwin Vega AI 12\'s on the rear deck, 6x9\'s in the rear sail panels, Monsoon Door panels With Memphis Audio 6.5\" Coaxials and tweeters, 1 farad EFX cap.
      Here check this out. Not a ton of info, but might get you started. [img]smile.gif[/img]
      In due time we'll have a install guide for those too :D
      Steve
      FirebirdV6.com/CamaroV6.com Administrator
      Stupid is rewarded with the ban button.
      Official Avatar Nazi according to Meatyshells :D
        I have the CompCams 1.6 roller tip rocker arms in mine. I could tell a little difference, but not a great amount. Some people say that it is better to do the full roller rockers, part number 25759-12, to get the full power potential. Hope this helps.
          GMPP has roller rockers for $11 a piece at gmpartsdirect.com
          I think they are roller tip.
          Hot Cammed LT1 Sleeper
            You mean these :) http://www.tagen.org/Engine.htm
            smaller pictures are better.
            Noticeable difference with just the rockers? IMHO no. If your going to go through all that trouble to get to the rockers spend an additional 4160 and do the CAM to. Powermax 2030
            94 Quasar Blue Z28<br /><a href=\"http://www.9t4z28.com\" target=\"_blank\">http://www.9t4z28.com</a><br /><a href=\"http://www.9t4z28.com/Dyno1.htm\" target=\"_blank\">http://www.9t4z28.com/Dyno1.htm</a>
              about how much would installation cost for rockers?
              New Car: 2004 GTP Comp G (Test Vehicle) 13.936@99.32 <br />Mods: Cylinder Filter,No Mufflers, 3.3\" <br />Old Car: 2000 Formula 13.124 @ 106.01 with 2.73\'s<br />Other Car: 1993 Firebird 16.1@83
                Not sure but I would suspec that a mechanic would book a minimum of 4 to 5 hours on it. I did mine myself with a little help to set them.
