Over the last few weeks I installed ported heads/intakes/TB and a ZZP GT cam. Overall things went pretty well. Car is running but has a few issues.
I could use any advice you guys have.
Issues:
1. Rough idle (j/k, it sounds awesome , check it out. http://www.glue.umd.edu/~kraeuter/video.html )
2. Car loses power. When I give it gas it either hesitates, stumbles, or goes and then cuts out higher in the rpm range. I think that this could be KR, low fuel pressure or too small injectors. My autotap is having issues so I can't really make any runs, it seems to have burnt out my serial port on my laptop or my cable is bad.
This problem could also be caused by questionable lifers. Most of them were not pumped like the installation reccomended but 1 or 2 were pumped, I attemtped to bleed them all out but I don't know whether it worked or not.
3. Exhaust leaks, I think I fixed this with paper gaskets and ultra copper for the header to head connections.
4. Slight tapping sound at certain rpms. This is barly noticible and could be cuased by the previous problems.
Things I've tried.
1. Full tank of high test gas.
2. Reinstalled MAF screen.
3. Fuel injector cleaner.
So far things have been getting slightly better the more I drive it, this is just what I've noticed so far.
Magnus, I remeber you had some issues similar to these with your install, what do you think.
Thanks,
Jon
[ November 17, 2003: Message edited by: jonny985 ]</p>
Issues:
Things I've tried.
Thanks,
Jon
