Yea, I was wonder if i could turn the 3.8 seriesII into a stroker motor by using the 4.1 crankshaft and pistons?
3.8 Stroker motor
it could work, as long as the rods were shortened enough and the piston compression height were also reduced in height. 3.4" stock stroke, 5.7" rod, and I dunno the compression height, but just make sure it all work out, as well as the crank actually fitting in our blocks.2001 Arctic White Firebird<br />More mods than I\'m allowed to list!
<blockquote>quote:</font><hr>Originally posted by Sandman:
Yea, I was wonder if i could turn the 3.8 seriesII into a stroker motor by using the 4.1 crankshaft and pistons?<hr></blockquote>
I think ZZP is working on this very thing. Check out the Coming soon section of ZZperformance.com2000 Firebird. Whisper Lid, True duals, TSP mail order tune, Built Tranny , TCI 2800 stall verter, B&M tranny cooler, Eaton LSD, 3.42 gears. Current best ET. 15.232 89.09 MPH 2.175 60ft on stock 3.42\'s and open diff.<a href=\"http://www.geocities.c
wow, check out this ZZP thing!?
i wonder if it will work on the L36 in our cars...
http://www.zzperformance.com/zzp/projects/amaft.htm
Zoomer has already built a L36 4.1 litre.
for his girlfriends GP GT. the car ran a 13.49 untuned. they are claiming 12's N/A
competion L36 short block will be avaliable soon. [img]graemlins/bowdown.gif[/img]97 GT coupe. SLP cai gutted,DHP, 180t-stat,EPP coolant plug,NGK\'s,STB\'s,ZZP pulleys,MAF screen u-bend&resonator removed,reflective concepts,GPS dual tips.<br />71 CHEVELLE 358ci 12.10@108 & 10.81 @121 on NOS w/1.47 60ft
by 187sharkHi all new to the community here. I have a 2014 RS 6 speed manual... and so about a year ago my tail lights got cracked and eventually the plastic housing...6 days ago
by ssms5411Still trying to find oil leak on my Camaro, it’s a tough one. I think it is the oil pressure sender myself. Leaking when raving and going into boost....2 weeks ago
