3.8 Stroker motor - FirebirdV6.com/CamaroV6.com Message Board
3.8 Stroker motor
  • 3.8 Stroker motor
    Yea, I was wonder if i could turn the 3.8 seriesII into a stroker motor by using the 4.1 crankshaft and pistons?
    IS THIS WHERE I\'M SUPPOSE TO BUILD MY INTERNET CAMARO THAT RUNS 10\'S TO LOW 11\'S ALL DAY LONG???
    it could work, as long as the rods were shortened enough and the piston compression height were also reduced in height. 3.4" stock stroke, 5.7" rod, and I dunno the compression height, but just make sure it all work out, as well as the crank actually fitting in our blocks.
      <blockquote>quote:</font><hr>Originally posted by Sandman:
      Yea, I was wonder if i could turn the 3.8 seriesII into a stroker motor by using the 4.1 crankshaft and pistons?<hr></blockquote>
      I think ZZP is working on this very thing. Check out the Coming soon section of ZZperformance.com
        Whoa, there's a 4.1?
          wow, check out this ZZP thing!?
          i wonder if it will work on the L36 in our cars...
          http://www.zzperformance.com/zzp/projects/amaft.htm
            Zoomer has already built a L36 4.1 litre.
            for his girlfriends GP GT. the car ran a 13.49 untuned. they are claiming 12's N/A
            competion L36 short block will be avaliable soon. [img]graemlins/bowdown.gif[/img]
            97 GT coupe. SLP cai gutted,DHP, 180t-stat,EPP coolant plug,NGK\'s,STB\'s,ZZP pulleys,MAF screen u-bend&resonator removed,reflective concepts,GPS dual tips.<br />71 CHEVELLE 358ci 12.10@108 & 10.81 @121 on NOS w/1.47 60ft
              Back in the early 80's there was a 4.1 option. IT wasn't as great as they thought it would be & was dropped.
              2013 Ram 1500 Big Horn
              94 comero 3.4
