well i did a cam install about 3 weeks ago. i still have a fully stock valvetrain. i just ordered new pushrods, springs and retainers from zzperformance.. i'm doing this because my car is shifting much higher now and i don't want crushed springs or anything like that.. how do i go about changing vavesprings, i have the tool to compress then. is this a difficult job..
going back into the motor
its pretty simple, I just rotate the motor until the perticular cyl is at TDC and use the spring compressor to squeeze the spring, then you can push against the piston and the retainer will come out, pull it all out, then put the new stuff in.
You may have to remove the coolant lines to get to the ones for cyl 6 (rear pass side)Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
