97 V6 (L36) to V8 (LS1) swap progress... - FirebirdV6.com/CamaroV6.com Message Board
  • 97 V6 (L36) to V8 (LS1) swap progress...
    To keep you all updated.
    Sat, 3/22:
    Removed exhaust from y-pipe back
    Removed torque arm
    Removed drive shaft
    Removed heat shields underneath gas tank
    Removed intake
    Sun, 3/23:
    Drained oil and coolant.
    Removed coolant hoses
    Removed heater hoses (to body)
    Disconnected PCM harness from body and dash harness. PCM sits on engine now.
    Disconnected and removed battery.
    Disconnected starter ground to body
    Unplugged brake sensor wires for front brakes.
    Unbolted power steering fluid resevior.
    Wed, 3/26:
    Picked up LS1 99 plastic fuel tank for $125
    Tue, 4/8:
    Removed radiator and fans
    Tue, 4/15:
    Disconnected brake lines
    Disconnected tranny lines and linkeage
    Removed brake fluid resevior
    Wed, 4/16:
    Dropped K-member w/Engine/Tranny/Wheels/Shocks
    Thu, 4/17:
    Removed Charcoal canister and EVAP pressure sensor from LS1 fuel tank
    Fri, 4/18:
    Ordered radiator from speed auto for 125 + shipping
    Removed fuel tank.
    Removed unneeded fuel lines (VAC and fuel return)
    Removed 3.8 charcoal canister (pass rear wheel well)
    Sat, 4/19:
    Picked up LS1 k-member
    Mon, 4/21:
    Parts arrived from TACreations.
    Assembled LS1 K-member.
    Removed EGR/EVAP/AIR from LS1.
    Removed motor mounts for poly mount install.
    Tue, 4/22:
    Assembled poly motor mounts
    Put LS1 on K-Member
    Unwrapped LS1 wiring harness
    Wed, 4/23:
    Removed EVAP/EGR/AIR/A/C wires from harness
    Removed V6 throttle cable
    Moved fuel PSI gauge over to the other side of engine bay
    Installed engine/tranny/k-member into car
    Transfered poly trans mount over
    Connected tranny linkage
    Thu, 4/24:
    Connected throttle cable
    Connected fuel pressure gauge
    Installed torque arm and drive shaft
    Installed brake fluid resevior and reconnected lines
    Fri, 4/25:
    Installed fuel tank and connected fuel lines
    Started to rewire the car.
    Sat, 4/26:
    Rewired the car some more.
    Installed V6 radiator for temp use.
    Started up the car.
    Drove the car.
    Sun, 4/27:
    Found out MAF wasn't getting power.
    Drove an even faster car.
    To do:
    Fix coolant temp gauge
    Fix fuel level gauge
    Clean up wiring harness
    [ April 28, 2003: Message edited by: Magnus ]</p>
    WHEN did you decide to do THIS!?!??? :cool:
      I was cruising around the street racing scene 2 fridays ago when I met up with a friend who has a highly modded 95 TA.. he told me it was for sale, I thought about it.. He rev'd it.. I'm like yea..... time to get rid of the 6..
      Thought about buying is car.. but I hate the LT1.. so I figure what the heck, why not just throw an LS1 in my car..
      and so it began.
        Well, at least its gonna be an LS1, I hope the change over goes well. Keep us posted on ur progress and any problems u encounter.
        97 Special Edition Bird , Short bus stlye special
          Wow, what a shame. (Shaking head in disbeleif)
          2004 Dodge Dakota 3.7 litres of raw power!!<br />Nothing but a 6!<br />Do you know for sure? John 3:18
            Big cam. Big stall. Big nuts.<br /><br /><a href=\"http://www.streetlethal.net/vids2/joenastycam.MPG\" target=\"_blank\">Idle/Rev Clip.</a>
              If I had money I would have done the same thing. ITs all about how fast you can go. Keith is reaching the potential of the 3.8 with not much left to mod. He has already ran a very impressive 13.6 na. He says he wants 11's NA. He will never get that fast with a V6 so it is time for him to swap.
              [ March 24, 2003: Message edited by: pgriffith ]</p>
                swapping to a v8 makes baby jesus cry..
                I to am a little shocked, but what the hell.. all the power to magnus.. he has given us alot and done alot of amazing stuff for our community..
                I wish you the best of luck with the swap.. and if you need any help (for some reason I doubt it) you know we will do our best to help you out..
                hell my roomate is an LS1 NUT! so if you run into a problem hit me up..
                later,
                Bill
                  What??!!
                  [ March 24, 2003: Message edited by: Shirl ]</p>
                  2004 CE Corvette 10.86@132mph
                  2011 Cadillac CTS-V
                  2006 Mitsubishi Eclipse GS
                    i'm fairly certain the fastest LT1 motor is faster than the fastest LS1 ;)
                    2011 Camaro LS 6M, in black.
                      i'm glad you are doing it and are happy about and all...but come on, the fact that you've spent so much damn money and time on that v6, and the fact that it's probably as fast as, maybe even faster than what your ls1 will run stock, it just doesn't make much sense that you are just going to switch all of a sudden.
                      well, either way, i hope you are happy with whatever you do. i know for sure that if i pulled up next to you with your v6 in your car, i'd be in much more awe than i would be if i pulled up to you in an ls1, and that's all honesty, keith.
                      good luck man.
                      2000 NBM M6 Camaro Z28<br />323/335
                        I got MAD props for the V6 all over town. Many people ask me if it's really a 6.
                        I'm sure the LS1 in a 97 will turn some heads.
                        With my weight reduction, my stock engine will be faster than quite a few others out there, plus rolling on nittos and skinnies helps... oh yea.. and the TTS long tubes I have. ;)
                          <blockquote>quote:</font><hr>Originally posted by Magnus:
                          <hr></blockquote>
                          eh, the majority of people that see your car won't know that you have an ls1 in there, so the turning heads thing prolly won't hold so true with that.
                          but, regardless, i was just making a point that i think you'd impress many more people if you had kept your v6 in your car, especially if they happen to encounter you one day on the street. nevertheless, i definetely understand the "move on to bigger and better things," but your car was pretty "bigger" and pretty "better," which makes me wonder why you changed.
                            <blockquote>quote:</font><hr>Originally posted by Only4U:
                            <hr></blockquote>
                            My thoughts excacly! I could not have said it any better my self. None of us would mind makeing a V8 go fast but when you do it in a V6 it is a different story. Personal i rather give more props to a person that made their V6 run low 13s-high 12s all motor than somebody that did an LS1 swap for the V6 and is now running those times because of the LS1. People wonder why we donot have alot of V6s in the 12sec range and even one in the 11sec range and it is because ethier A) they trade their 6 for an SS or Z or B) they swap in a V8. I really don't like the stang V6s but i will give the owners props because they are decated to there cars and they try to make them as fast as they can. Not maney people are willing to do that over here and i feel somewhat sadden by it. The 3.8 has so much pontetal but not maney people want to take the time to fully explore it. Most just give up and take the easy way out, which is a V8. I am not trying to dog on you Keith on your desion but that is just how i feel.
                            [ March 24, 2003: Message edited by: toast ]</p>
                              hey, no hard feelings at all. I appreciate all of your feedback. [img]smile.gif[/img]
                              I've put plenty of time and $$$ into the V6. I've recieved my props for it and am proud of what I have done.. but it's time for me to see what I can do with an LS1.
                              I just need that V8 sound with the added power.
                              My LS1 plans:
                              sub 3000 lb car (like it already is)
                              big cam, converter, gear
                              I'd like to hit 10's NA with that setup. It's basically my V6 setup with only 2 more cyl's.
