2000 grand am heads - FirebirdV6.com/CamaroV6.com Message Board
2000 grand am heads
  • 2000 grand am heads
    Will 2000 grand am 3.4 heads work on a 94 3.4 f-body. thanks
    94 3.4L firebird<br />BMR STB, BMR swaybars, H&R springs, Custom air intake, 160 temp stat, slp fan switch,aluminum 1 piece driveshaft, LCA reloc brackets and billet LCA\'s, Masitaly 18x8 wheels, Kumho Ecsta 245/40/18\'s , Custom exhaust, catco High flow cat, spohn panhard and custom upper rod, MSD blaster coils, MSD 6A, APC seats on the floor of my apartment and headers on the way
    will thye bolt on.. yes , will thye work without a lot of other work , no,
    its a very difficult and time consuming swap, im in the process of it right now, and only one other person has done it before me ( russell)
    -Aaron, AKA ATL2001<br />93 3.4L <br /><a href=\"http://www.ilfba.com\" target=\"_blank\">www.ilfba.com</a>
      <blockquote>quote:</font><hr>Originally posted by firstlove94:
      Will 2000 grand am 3.4 heads work on a 94 3.4 f-body. thanks<hr></blockquote>
      Yes, talk to Russell.
      ~Derrick <a href=\"http://www.appstate.edu/~do54457/\" target=\"_blank\"><i>My Webpage</i></a><br /><b>\'96 3.8L V6 M5 Firebird Y87</b> | <b>162.8 RWHP</b> / <b>196.7 RWTQ</b> <br /><b>•</b> SLP CAI <b>•</b> <a href=\"http://tech.firebirdv6.com/y87.html\" target=\"_blank\"><b>Y87</b> Package</a> - 3.23s <b>•</b> 180º thermo w/ fan switch <b>•</b> TB spacer from DEE<br />1991 Jeep Cherokee Laredo 4x4
        Is there a benefit?
          <blockquote>quote:</font><hr>Originally posted by xjarayax:
          Is there a benefit?<hr></blockquote>
          He MIGHT have the chance to get them cheap and in need of new ones, I guess...maybe...
          <b>2000 NBM Pontiac Firebird</b><br />3800GT Performance Package<br /><br />Intake, Magnaflow Cat, Flowmaster Cat-Back
            only if you think that air flow is a good thing..
            the gen II or gen III heads will flow more stock than a set of fully ported gen I heads (the stock iron ones)
            also they have canted valves, more options for valve springs, 1.6 ratio roller fulcrum rockers stock, weigh about 1/2 the weight of stock heads, and are alumnium so the heads dicapate heat faster
            (thats all i can think of off the top of my head as 4:30 AM)
              3.8L heads are not aluminum
                <blockquote>quote:</font><hr>Originally posted by slomaro:
                3.8L heads are not aluminum<hr></blockquote>They are talking about the 3.4
                2000 Firebird. Whisper Lid, True duals, TSP mail order tune, Built Tranny , TCI 2800 stall verter, B&M tranny cooler, Eaton LSD, 3.42 gears. Current best ET. 15.232 89.09 MPH 2.175 60ft on stock 3.42\'s and open diff.<a href=\"http://www.geocities.c
