need help figureing this out... - FirebirdV6.com/CamaroV6.com Message Board
  • need help figureing this out...
    ok.. i have a problem going on with my car..its either something having to do with the fuel system, or ignition. when i hit the gas, my engine shakes as if its not getting enough fuel, or as if its misfireing. but when i slowly mash the pedal..little bit at a time..it doesnt bog or anything throughout the RPM range. but if i just slightly push on it a little harder, it feels like im a 2 banger. any ideas on what this is? it JUST happened, out of nowhere.. and for some reason, i got the SES light, but after a little bit of driving it went away. HELP PLEASE!! i had to turn down a race to a civic today...pretty sad
    96 Camaro M5. Dark metallic gree (?dont know the offical color name)<br />Home made Intake :: Headers, 3inch headers back to Flowmaster muffler :: spec stage 3 clutch Now installed, waiting for 3.42\'s and LSD next month<br /><a href=\"http://photobucket.com/albums/y192/RiceEatingCamaro/?action=view&current=newcar.jpg\" target=\"_blank\">My Car</a> <br /><br />Totalled Car.<br /><a href=\"http://bellsouthpwp.net/s/k/sk8er305/\" target=\"_blank\">96 CamaroRS</a>
    Plugs and wires? You guys should start doing the obvious things first. I see some many posts of this nature. Fuel filter is a cheap guess too.
    [ April 29, 2002: Message edited by: Dom ]</p>
      ya..last time ihad this problem, it was on my 97 firebird, i changed the spark plugs, wires AND coilpacks..all the ignition..and it still did it.. theni replaced the fuel filter, still did it..
      i did all that work on that thing just to find out that it was the transmission that was slipping.. but that was an a4. i have an m5 on my camaro
        could be a clogged cat too.
          no codes?
            what about fuel pump? my car would bog down when I hit the pedal and shook bad had trouble starting.
            1995 Camaro 3.4 v6. Dead<br />1995 Trans Am FIPK.
              i bet you that it's your cat. when they go to crap, the car won't run worth a damn
              97 CAMARO RS<br />12.9@103mph<br />best 60ft..1.9 ( on street tires)<br /> 1.7 (on gas)<br />turbo supra 12.5@119mph (street tires)<br />new times to come sporting the sp63gt
                Cat, or the same problem on an older F-bod (2.8) was the TPS. Went wacky on me. Replaced it and it mostly fixed it. Cat was clogged too.
                -Brian
                P.S. TPS=Throttle Position Sensor
                [ April 30, 2002: Message edited by: Brian Dieckman ]</p>
                Maroon 1995 Camaro<br />No mods yet...<br />Lucky to have found this site!
