cam help - FirebirdV6.com/CamaroV6.com Message Board
cam help
  • cam help
    I just bought a 3.4L from trans am creations and I had some ?'s about the cam I was going to put in it.
    -2030 Cam
    http://www.cranecams.com/master/apps...#2.%20CompuCam
    Here is the question, how does the MAP sensor on the 3.4L compenstate for low manifold vac if it is used to the stock cam with a high manifold at idle. How will the MAP sensor effect the cam?
    I would also like some suggestions for a bigger cam, I want some lope at idle. [img]smile.gif[/img]
    Thx
    1995 3.4L<p>K@N FIPK, SLP Fan Switch, Jet Chips 2 stage, Jet Chips Underdrive Pulley, Accel Coils, Nology Plug wires, RKSport Headers, Catco Cat
    6 days ago
