Ok i know this has been throw around but i would like to know about this setup - FirebirdV6.com/CamaroV6.com Message Board
  • Ok i know this has been throw around but i would like to know about this setup
    If I were to get these valve springs and push rods
    http://www.grandprixstore.com/Mercha...egory_Code=004
    And get this Cam
    Would i lose anyhitng like topend or lowend.
    I will be doing this and later forged pistons with a 10.1 compression.
    Will this hold up to a high shot of direct port and if the answer is yes what shot could i run .
    If this setup is not good recomend another cam and please post the specs that the cam is and why
    I think thats a question a lot of us would like answered :D
    Thanks!
      Tom@Supersix can get you all of these products. He is definately the man to talk to for V6 f-body stuff. [img]smile.gif[/img]
      You'll want a higher rate spring if you plan to rev higher.
      That is a good cam for nitrous. Tom@Supersix can also help you find tune your cam selection to your car.
      The size shot you can run is not dependant on the cam and springs, but more so on the crank and rods/pistons.
      Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
        will the grand prix cam mentioned above work on the 2000 3.8L v6 without having to modify anything else?
        Street Lethal Performance<br />2000 Black Firebird Y87<br />3.42\'s, Torsen Limited Slip, 160 powerstat,<br />Manual Fan Switch, Cutout exhaust, Whisper Ram Air CAI,<br />K&N filter, Zex spark plugs, MSD plug wires, MAF screen removed.<p>AIM: FIREBIRDRUMBLE00<br /><a href=\"http://www.streetlethalperformance.com/profiles/gazmentselman/gazmentselman.html\" target=\"_blank\">Street Lethal Performance Profile</a>
        • Manimal
          Coil springs
          by Manimal
          6 days ago
        • Manimal
          Newby here
          by Manimal
