wideband setup - FirebirdV6.com/CamaroV6.com Message Board
wideband setup
  • wideband setup
    I'm thinking of getting the plx 300, anyone heard good or bad things about them. I like that you can put the sensor in the existing O2 spot. Also I won't have to buy a gauge since it comes with one already. For $315.00 shipped I think it is a good deal.
    arent you supposed to put a wide band sensor in the y pipe before the cat to exhaust from both sides of engine?
    01 Firebird A4 3.42
    Powerdyne @ 6 PSI
    and other mods
      yepp.. its hotter there (important), and you will get a more accurate reading.
      you want it right after the Y-pipe for a single sensor config.. or for a dual you want it in the collectors..
      If you get the EIO version of HPTuners you can get the LC-1
      from what i can tell its a $200 version of the LM-1 jsut w/o a display.. its basily jsut a wideband controller.. then what you would do is take that and run it into your EIO hptuners cable and log/view all the data from there..
      I wish i had that option when i bought all of my stuff.. because the LC-1 is a sweet deal.
