Hey, Looking to put a 75-100 shot of N2O on my 97 Camaro 3.8. Need Fuel and need to pull timing. Gonna be running NGK TR6 Plugs (1 step colder) Figuring it will pull about 4* timing if I put a 175 ohm resistor in the plug for the IAT sensor. This will make the ECM think that the IAT is about 170degrees. However, need more fuel! can't figure what i can do to get it. Don't really want to go with a wet kit, but prob. have to. Suggestions? Comments? THanks
N2O Questions
Originally posted by White97RS:
Suggestions? Comments? THanksMatt
1998 Mystic Teal Camaro M5
Why would you want the ECU thinking that it is running 170 IAT that will lean out the mixture.
My IAC in my V6 camaro was telling the comp that it was getting hot air, I ran it like that for a long time and I burned valves.
You can parrel a resistor in with the IAT and make it think the air is a little cooler than it realy is all the time, adding a little more fuel all the time.\'85 Z28, T-tops new LG4 and TH700<br />\'85 3.4L 5-speed<br />mods: <a href=\"http://www.cardomain.com/id/oil_pan_4\" target=\"_blank\">http://www.cardomain.com/id/oil_pan_4</a> the nitrous exhaust O2 safety, pg 3. <br />Areo space materal engineer wantabe
dont mess with sensors to make adjustments..do it the right way and get a tuner (HP Tuners, DHP, etc.)<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
^ correct..IF its a dry kit..properly installed..it will pull timing for you..you should be able to run a 75 dry shot on the stock pump..ANYTHING over and i personally would upgrade<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
